FoodSaver Tilia 801 Food Saver Vacuum Sealing System Logo
A
Anonymous Posted on Oct 15, 2014
The progress light on the food saver is flashing red
I can not seal the plastic
Lawrence Oravetz
Level 3:
  • FoodSaver Master 10,558 Answers
  • Posted on Oct 15, 2014
Lawrence Oravetz
FoodSaver Master
Level 3:
Answers
10558
Questions
Helped
2694895
Points
29284
The heater bar is too hot. Allow it to cool for a while before resuming sealing.
  • coney590 Dec 27, 2015
    Did everything to stop the led light from flashing nothing works havent used it for months
Cannot get it to vacuum.
Does it try to vacuum but never flattens the bag? Make sure the bag you are using is completely sealed on the opposite end. Otherwise, the seal on the sealer is probably allowing air to leak into the sealer. If it has a foam sealer, I've found it sometimes helps to run the foam sealer under water, squeeze out the excess water, reinsert the foam sealer (make sure it is seated all the way) and then try again to seal the bag.
I have wasted quit a bit of the bags because the food saver is not sealing completely. It leaves a 1/4 to a 1/2 inch unsealed therefore I can not vacuum seal. What am I doing wrong
Try making a seal with nothing liquid in bag, check seal on bag after. If seal looks good it could just be liquid getting on seal area causing it not to seal. There are tips online on how to help prevent this (example: placing rolled up paper towel sheet). If seal still looks bad than you may have a bad spot on the heat seal wire.
Jan 23, 2016 • Vacuums
1helpful
My vacmaster pro 160 does not seal bags
Try with a different bag ( I have the same problem, the bags are not the same) if still not working, the you have faulty pump
1helpful
2answers
Why there say tray full red light
The tape trick didn't work for me. Had to cut the wires. Works for now.
My Rival food saver does not vacuum air out
We discovered we were not moving the bags in far enough to be grabbed properly. After pushing in the bag before closing the unit we found it started sealing properly. This was on an older system, so be sure the bags you're sealling are between the black rubber rectanglar sections before closing the door.
If this is for a canister, be sure the rubber around the lid is seated properly. The rubber can be removed, cleaned and wiped dry. Clean out the lid and dry it too. Reseat the rubber seal and try again... Hope this helps.
Apr 19, 2010 • Vacuums
3helpful
My vaccuum has no more suction
There is no drive belt on a progressive drive vacuum. It is direct drive meaning it is attached via the motor. No vacuum means no air flow somewhere in the unit. Torn bag,Wrong bag, pluged filter under bag.Make sure the opening in the bag is the correct size,too big and it will not seal. Make sure when you close the housing it seals also. No housing seal no vacuum. Kenmore vacuums tend to be plastic housings. Cracks are comon in the wheel housing area. Check there first. Plastic expoxy will work with this fix if so needed.
Top FoodSaver Vacuums Experts
ADMIN Andrew
ADMIN Andrew
goneforever.
Curt mueller
Are you a FoodSaver Vacuum Expert? Answer questions, earn points and help others
