Are you using the whitest whites option? http://www.whirlpool.com/digitalassets/WTW8000BW/Use%20and%20Care_EN.pdf
pgs 15-16 troubleshoot not cleaning
Check your settings for your load.
Did you know when ecowash is on will reduce water temp. regardless of setting? pg4 #7
Have you used the clean washer cycle after 30 loads? pg11
chlorine bleach is a highly corrosive addition to laundry that is not necessary... try Borax and Hot water. If the clothes sat in the Bleach for the entire wash cycle it would damage them and shorten the life of the clothing fibers considerably...
lf means long fill check your fill hoses and make sure the water is comeing out. sounds like a problem with your inlet valve and/or your water from your house is not right.
If the washer does not come equipped with a "Clean" cycle, then run the washer on it's hottest setting. "Sanitary" or "Whitest Whites" will do. Hope this helps.
