5303P LCD 2Way Security System with Remote Start and 4Button Remot Logo
A
Anonymous Posted on Oct 15, 2014
<!-- from fixya rte -->How to set the clock in the remote start - 5303P LCD 2Way Security System with Remote Start and 4Button Remot
Derrick Schultz
Level 3:
Top Expert:
  • Python Master 11,405 Answers
  • Posted on Jan 30, 2019
Derrick Schultz
Python Master
Level 3:
Top Expert:
Answers
11405
Questions
0
Helped
2329921
Points
23972
I got this free Pdf manual from an online store for free and I don't think Ive visited a mechanic or fixya for help for more than 3-4 times out of the all the times I fixed the chipper in these 4 years
How do I set the time on a sanyo KHS 1872 air conditioning remote? not the timer but the time the clock?
the remote does not care what time it is. The AC unit has all the unit control's and info on it. Just like a tv remote the tv has all the info on it.
How do I set the time on my little old Thomson CS86M mini Hi-Fi?
If you have a remote version here is how it works.
Press timer menu, hours should flash, then press up an down arrows until you get to clock set. Press enter on remote.
press up an down arrows to set hours, then press enter. Minutes now flash, press up an down to set, press enter on remote clock starts.
1helpful
2answers
Aiwa XR-EM50
This was easy.. download the manual here:
http://www.nodevice.com/download/user_manual/aiwa+xr-em50.html
From the manual:
Clock Adjustment: (Page 7)
Setting the clock
1 Hold down SHIFT and press CLOCK on the remote
control.
When the unit is turned off, you can also press SET.
2 Within 6 seconds, press "< <" (rewind icon) or > > (fast forward icon) to set thetime.
Each press changes the time in 1-minute steps.
Holding these buttons down will vary the time in 10-minute
units.
3 Press SET.
The time display stops flashing and the clock starts from
00 seconds.
When setting the clock on the unit in stop mode, hold down
"square" (stop icon) and press "> >" in step 1. After setting the time in step 2,
press TONE in step 3.
To display the time while the power is on
Hold down SHIFT and press CLOCK on the remote control.
The time will be displayed for 6 seconds.
To switch to the 24-hour standard
Display the time and press s within 6 seconds.
With each press, the clock alternates between 12- and 24-
hour standard time.
Tip:
In the 12-hour standard, "AM12:00" indicates midnight and
"PM12:00" noon.
If the clock display flashes when the unit is turned
off
There has been a power interruption. Reset the clock.
Bass / Treb Adjustment: (Page 11)
1) Press BAS or TRE
2) Within 6 seconds, turn VOLUME (press VOLUME +,- on the remote control).
Each level can be adjusted from "-2" to "+5".
Good Luck!
4helpful
3answers
Panasonic =iv NV-MV40 , how to set the clock please
You can download the user manual for free from the Panasonic website.
1helpful
2answers
I have a used JVC FS-B70 with no remote. How do I set the time on the clock?
To set the clock go to the link below page 9 will tell you how to set clock.
http://resources.jvc.com/Resources/00/00/97/MB002ien.pdf
On the remote control ONLY:
1 Press CLOCK/TIMER.
The hour digits start flashing on the display.
2 Press UP or DOWN to adjust
the hour, then press CLOCK/
TIMER.
The minute digits start flashing.
• When you press and hold UP or
DOWN, the hour digit changes
continuously.
3 Press UP or DOWN to adjust the
minute, then press CLOCK/TIMER.
The built-in clock starts.
• When you unplug the power cord or if a power failure occurs
The clock is reset to "AM 12:00" right away. If this happens, set
the clock again.
• The clock may gain or lose 1 to 2 minutes per month
If this happens, reset the clock.
15helpful
How do i set the time on the remote
Setting the clock
To set the clock press and hold F for five seconds, the transceiver will chirp twice and the hour selection will
start flashing. Immediately press Aux to advance the hour selection or star to reverse the hour selection.
Once the correct hour is displayed press F again and the minute selection will start flashing. Then press Aux to advance the minute selection or Star to reverse the minute selection. Once the correct time is displayed simply stop pressing all buttons for 15 seconds and the transceiver will automatically exit the clock mode.
Cannot set clock or timer
turn the system off and press the clock button on the remote after the clock illuminates hold the memory button on the remote until the hour starts to blink then press the preset up or down to change ( go through 12 hours to change AM PM) then press memory to get to the minutes after setting the minutes press memory to save
6helpful
3answers
Cant get the Unit to respond to the remote control
My remote won't work. It will work once, maybe twice and then no response from it. New batteries, haven't dropped it, etc.. HELP !!
2helpful
2answers
Temperature sensor
I have this clock and just finished getting it all working again. At first I kept messing around with the AAA batteries in the remote unit, finally realized there were AA batts in the back of the main clock/display unit. Replaced those, pressed the reset button next to the battery compartment. Pressed the reset button on the remote unit (it's under the back lid next to the AAA battery compartment). Little red light on the remote unit started flashing and remote temp showed on the main display. Then you have to wait for atomic time to reset itself or set the time and other display options manually - I kept messing around with the various buttons until I figured out how to do this (atomic time never reset) - start by holding down the smaller "AL" button on the top next to the big snooze/light button, use top two side buttons for up/down, use the AL button to go to next setting.
1helpful
How to set clock....
http://www.bose.com/pdf/customer_service/owners/og_wrcd.pdf Hold down either Time < or Time > or press either button twice in a row... clock should start flashing
Top Python Vehicle Parts & Accessories Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Python Vehicle Part and Accessory Expert? Answer questions, earn points and help others
