Need a installation diagram to replace a drive belt on craftsman riding mower
I don't have a diagram but I can tell you how. First remove the deck and deck belt. Then remove the engine belt keepers. Remove the Clutching Idler and bracket (the one with the spring attached). Then you can remove the drive belt from the mower. When installing your drive belt, make sure the belt goes around the clutching idler and then on the inside of the stationary idler (flat side of belt to the stationary idler). Reinstall engine belt keepers and then deck and deck belt.
If you have a Craftsman, under the seat is the model number. Go Here to get the operators manual. The manual will have all the belt diagrams. Water Filters Lawn Garden Appliance Parts
SOURCE: how to install mower deck belt on a lt1000 craftsman riding mower
The manual will cover it.
http://www.disruptit.com/manuals/L0104168.pdf
SOURCE: i need belt diagram for 42 in deck
You can go to the Sears website an download a free owners manual that shows what you need.
SOURCE: Belt Diagram needed on Craftsman Kohler Command 20 Hp RidingMower
Go to... http://www.searspartsdirect.com/partsdirect/index.action Enter your model #, click enter, then scroll down to the sudcomponent list and click on 'Mower Deck' if it's your blade belt you need to see or 'Ground Drive' for your transmission belt. Hope that helps. Dwain
SOURCE: i need a manual to show me how to adjust the belt
Here is a link to the manual
Please rate this a fixya.
SOURCE: Sears Craftsman riding mower V belt getting chewed
I believe you may have the belt over one or more of the belt retainers next to the pulleys. They are 5 or 6 inches long and about a 1/4 inch in diameter. You have to loosen them when you put the belt on then adjust them to where they are just barely touching the back of the belt. They keep the belt from jumping off.
