Question about NorStar T7208 Corded Phone
How do i change the admin password without knowing the current password for t7208
I need to reprogram the extension names from past employees to current and it will not allow me to without the admin username/password
    New Friend:
  • 49 Answers
Find your answer in the user manual: Nortel networks phone manual t7208
Posted on Oct 06, 2015
  • 71 Answers
Usually the admin password is left at admin (23646)
Posted on Feb 11, 2015
SOURCE:
SOURCE: Trying to change the name on a phone
1. Press FEATURE * * 2 6 6 3 4 4
2. Enter Password: 2 6 6 3 4 4
3.Press the top grey button (the set on the lower right hand side with the grey buttons closest together)
4. press the button under the one you just pushed until you get the desired name/ or the one with no name
5.press the same button as in number 3 (once only)
6.press the same button as in number 4 (2 times) you should get the name and a soft key button for change
7.type the name like a text message
8. once you filled it in hit the same button as in number 4.
9. hit release
Posted on Oct 25, 2008
SOURCE: Employee's mailbox locked and No one knows Admin password
Jessie711 - You Rock! Your post on the 21st fixed my problem :)
Posted on Nov 21, 2008
SOURCE: changing employee name on extension
http://www.phonserv.com/1_m7310_phone_meridian_norstar_phone_system.htm
This has PDF file that will give instructions.
Also this link has more instructions:
http://www.phonserv.com/1_PDF_user_guide_meridian_norstar_phone_systems.htm
To Change the Name on a Mailbox:
1. Log into system administration
2. Select the softkey under "MBOX"
3. Select the softkey under "Chng"
4. Enter the mailbox number (extension. you want to change the name on
5. The display shows "Reset Password"
6. Select the softkey under "Next", keep hitting "Next" until the display shows the name
7. Select the softkey under "Chng" to enter a new name
8. Enter the name using the dial pad. Enter last name first, press "# #" to enter a comma and then enter the first name. When spelling the name, press "#" to move to the next character
9. Select the softkey under "Next" to save the change
10. Hit the release button
Posted on Mar 10, 2009
ynotphone
  • 192 Answers
SOURCE: How do you change passwords without knowing previous passwords in order to change voicemail greeting??
Actually, even as a technician, you will never know the origonal password.
But you can get in to reset the existing password back to 0 0 0 0.
There are a couple of steps; depending on your voicemail system, voicemail's are done differently, but try this first.
got to a M7310 set
-> dial FEATURE 9 8 3
-> password: 1 0 2 0 0 0 0
-> you should now see ADMIN and under that MBOX, AA, OTHR
press MBOX
-> press CHNG
-> dial the extension of the phones that you need changed
-> you should now see PASSWORD and under it RESET, press RESET (This resets the mailbox back to 4- zero's)
-> hit the * to back up and repeat fopr all the other extensions.
-> hit RLS after all is done and voila... you have now changed those passwords to those mailboxes.
Now when the new users dial F981 at their desks, and dial 0 0 0 0 the first prompt they get is pleasde change password.
Posted on Apr 17, 2009
consultel1
  • 860 Answers
SOURCE: Program a new Nortel m7310 phone with an existing extension
If the extension was a swap of the old M7310 with a new(ish) M7310 no additional programming should be necessary. However if the phone was replaced with another type of nortel set(M7208, M7324,T7313 etc.) then the phone will default to its base features. To re-program the feature keys press feature *3, the button you wish to program, and the feature code for that button
Posted on Sep 28, 2009
How to program nortel T7208 to have feature > 981 with an "other" option
After entering the mailbox access F981, press "#", the display should change from Pswd: to Log:. Now, enter the alternate mailbox number followed by the password for that box and "#". The remainder of the prompts should be the same as accessing the 'native' mailbox.
Nov 14, 2012 | Nortel Business Series Terminal T7208 -...
Change display names
A problem with answering this question is first that the main SYSTEM keeps this info not the handset, so for the 3x8, 6x16, and 8x24 systems you can do the following (PROVIDED, the installer did not change the passwords to access).
Enter Password: 2 6 6 3 4 4 Display will read: " A. Configuration"
Press: NEXT Display will read: "B. General Admin"
(NEXT is always the button on the right of your lines/extension list, 2nd button down from top.)
4. Press: SHOW Display will read: "1. Sys speed dial" (SHOW is one key up from NEXT)
5. Press: NEXT Display will read: "2. Names"
6. Press the SHOW Display will read: "Set names"
7. Press: SHOW Display will read: "Show set:__"
8. Enter the extension number of which you wish to change the name Display will read: "<##:name>"
9. Press the CHANGE softkey
10. Using the dial pad spell out the name Ex: If you need the letter K press the 5 key twice and then press # to confirm the letter. Continue until the entire first name is spelled. (note: you are limited to 7 characters)
11. Press: NEXT (if you fail to do this step, the name will not be saved!!!)
12. Press the RLS key
I may be mistaken however I think you have to be on a model M7310, T7316, or M7324 phone (there should be at least one usually at the main desk) in order to program I don't think you can directly do it from the T7208.
Hope this helps.
May 04, 2010 | Nortel Business Series Terminal T7208 -...
An employee changed the password to the voicemail, and they are no longer with us. How do I override their password and change it back to the default password for the new employee?
Depending on the type of voicemail you have, you''ll have to login to the admin mailbox. That's done by pressing your voicemail key or intercom 777. If you have a Partnermail VS the admin mailbox is 99 with the default password of 1234. If you mave a Partner Messaging System the admin mailbox is 0 with a default password of 1234 or 123456. Once your into the admin mailbox press 9 for admin programming. ,(depending on version) press either 2 or 4 administer extensions, enter the mailbox number of the box you want to reset, press 3 to re initalize the password, hang up when done
Apr 09, 2010 | Avaya Lucent Partner 616 Phone
Have the Lucent MLX-5D, employee has terminated
You will need to login to the Admin part of the voicemail and reset the password.
Do you know how to do this?
Oct 13, 2009 | Avaya Lucent Partner 616 Phone
got to a M7310 set
press MBOX
-> press CHNG
Apr 15, 2009 | NorStar Meridian M7310 Phone
NORSTAR phone system/directory of employees
First thing, these new employees have the extensions of the old employees correct, otherwise more changes that what I gave you here will not work properly, example when you hear Press 1 it went to Joe, and Mary is where Joe used to be; that will work. But it Mary is where Steve used to be, pressing one will go where Joe was and not to Mary. Understand?
Ok, for the first part- changing the greeting in the Auto Attendant via CCR tree... you have to get into the ADMIN mailbox:
-> FEATURE 9 8 3
-> Password 1020000 (this is the default password, but can be changed)
-> OTHR
-> CCR
-> ADMIN
-> TREE 1 and press OK
-> CHNG
-> Path 0
-> REC then press PLAY to listen to the greeting, and ensure that is the one that you need to change
-> REC the new message
-> remember to SAVE! otherwise all is for not.
THIS MAY BE REQUIRED FOR OTHER TREES ex 2 or 3, listen too all trees and change if required... same steps to get into the trees and prompts.
The call forwarding to Voicemail: You need to know how to manuver around programming via the template on your phone:
-> press FEATURE 9 8 5 to get the DN of voicemail
-> FEATURE * * 2 6 6 3 4 4 (**CONFIG)
-> password: 2 6 6 3 4 4
->TERMINALS&SETS and Enter
-> type in extension that you want to change and Enter
-> next to CAPABILITIES and Enter
-> FWD NO ANSWER and Enter and put in the DN of the voicemail
-> hit NEXT and then RLS and voila, you are done!
Apr 06, 2009 | NorStar Meridian M7310 Phone
We have a Toshiba DKT 3210-SD phone system and can't seem to figure out how to reprogram the name of the person that is using that phone, The names located in the top left hand corner of the screen are of...
If you have the software you can get in and program via station assignment.
If you admin, programmed on any ext you can program.
If not we can remote into your system and change them.
info@ameritelnj.com
Tony
Jan 26, 2009 | Toshiba DKT-2020-SD telephone
Cannot change name ID for each extension, shows old names
Read several on-line manuals and found out another way to access programming trees. It was a confusing mess and was mostly trial and error. The 4 keys under the read out screen are a key factor and knowing how those buttons interact with each other is important. In the process I screwed up regular functions because the password that allows set-up using the feature codes cannot be changed. Not a user friendly set-up at all and the initial manual virtually useless for some needs.
Nov 25, 2008 | NorStar M7310 Corded Phone
Voice message, reprogramming extensions
How did you program the voicemail so a caller can not leave a voicemail to a particular extension? Line ownership? SO a call goes directly to a milbox?
How can you reprogram the voice message????? Which one, for a particular user or the main Auto attendant greeting????
You have to know the admin login to change a mailbox password.
For that, you need to know which voicemail system this is.
When you log in to check your mail, the lady says, "welcome to Partner......"
Please fill in the blanks.
Nov 18, 2008 | Avaya Lucent Partner 616 Phone
Cannot find instructions to name a telephone
You can try the default code for admin programming I am assuming this is a norstar? If the codes were not changed try this
2. Enter Password: 2 6 6 3 4 4 Display will read: " A. Configuration"
Using the navigation keys, as displayed below, follow the next simple steps:
3. Press: NEXT Display will read: "B. General Admin"
May 21, 2008 | NorStar T7208 Corded Phone
NorStar T7208 Corded Phone Logo
452 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
Thomas F. Schneider
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
