Remote Start System  Logo
A
Anonymous Posted on Oct 14, 2014
I changed the battery in my toyota truck and now my viper 5301 wont work
It will try to start but wont engage I think it needs to be reprogramed but the owners guide does not tell me this any thoughts
Derrick Schultz
Level 3:
Top Expert:
  • Viper Master 11,405 Answers
  • Posted on Feb 06, 2019
Derrick Schultz
Viper Master
Level 3:
Top Expert:
Answers
11405
Questions
0
Helped
2327515
Points
23972
I got this free Pdf manual from reliable-store for free and I don't think Ive visited a mechan ic or fixya for help for more than 3-4 times out of the 20 times I fixed the chipper in these 4 yearsmust try this bitman and reliable-store. Both are good
5 Related Answers
Anonymous
  • Posted on Nov 18, 2009
SOURCE: Can you lock the viper 5301 keypad?
Yes.
Press and hold Function (f) for 12 seconds.
Press and hold Lock for 2 seconds
(The keypad will light up)
If the green light by the lock button shows keypad lock on/off (no light).
Press lock- green light comes on.
Press and hold f for 2 seconds
Command entered
Press and hold f or wait 30 seconds for it to time out and the amber light turn off.
Anonymous
  • Posted on Jan 26, 2010
SOURCE: Where can I get a Viper 5301 installation manual?
http://www.directeddealers.com then to manuals and it downloads a pdf file.
Anonymous
  • 344 Answers
  • Posted on Feb 15, 2010
SOURCE: I have a Viper LE 5301 remote starter. Currently,
rest the modual to factory default
nonontech
Lebanon Raingam
  • 4737 Answers
  • Posted on Feb 05, 2011
SOURCE: i m looking for the
You can download it HERE. Open the link and click "Download (1,014KB)" to download. I've uploaded it as a winrar file. The document is in PDF format, you'll need winzip or winrar to open the contents of the file. You'll also need a pdf reader like Adobe Reader to open the document on your computer. If you haven't installed a pdf reader, Click Here to download Adobe Reader.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Anonymous
  • 18 Answers
  • Posted on Feb 07, 2011
SOURCE: Change VIPER Responder One runtime
Actually the first solution may or may not be true. If whomever installed the remote starter "locked" the programming with a bitwriter, then you will need to take it back to someone with a bitwriter to unlock and change the setting. If it was not locked then you can change run times for that model yourself. You have choices of 12, 24 or 60 minutes. 12 is the factory setting (with a bitwriter you can choose in one minute increments). If your system is unlocked this is how you can change the runtime setting. It's a bit of a pain so you might want to write it down. There should be a small programming button attached to wires coming from the "brain". First, locate that button. 1. Turn ignition key on then back off. 2. Quickly push and HOLD the programming button. If the horn was hooked up to the remote start system, it should honk once. (If it wasn't you'll have to look for a small led status light on the brain that should flash once) To change runtime, keep holding the button down till the horn honks twice (or the led flashes twice). 3. Release button after horn honks twice (or led flashes twice.) You are now in menu two where runtime is set. 4. Within 10 seconds, press and release the programming button two times. Now push and HOLD the programming button. You are now on feature two of menu two (runtime options). While still holding the programming button in, press the remote start button on the fob the number of times that corresponds with the run time you want. once = 12 minutes, twice = 24 minutes and three times equals 60 minutes. After selection has been made release programming button. The programming sequence will be cancelled if any of the following occur: Ignition is turned on or programming button is pressed too many times or more than 25 seconds elapses between steps. Like I said, it is a pain to do manually and there is a possibility you could mess up other settings if you get it wrong. But this is what the install manual states if you want to give it a go. Good luck!
I have the viper 5301 2 way in my 2001 Nissan quest i press the remote start after the car is warm up everything on the dash board came up the airbag light is blinking the abs light is on ,battery light,...
Module is in short circuit disconnect and send it to lab for reprogramming check for door signals or divines the the central module bc is shorted with the inmovilaicer
Vehicle will respond but not lock/unlock
reprogram the remotes by following the vehicles owner Manuel
if you can't get them reprogrammed then its dealer time.
Crank but no start
If your truck already has a factory alarm you will need to get a pass module installed to bypass the factory alarm.
Remote starter not working
Check to make sure the remote start kill switch isn't broken. There should be a switch under your driver seat or gas pedal that turns your engine off if someone tries to drive off with your car while you're warming it up. If that switch is damaged, it can trick your remote start system into thinking there's someone in your car, and preventing the system from starting up at all.
5301 LE 2 Way Car Remote Starter System has stopped making the confirmation tones when it starts or shuts off the car. Does anyone know how to resolve this?
looks like it's hard to get..
why don't u try online
some websites deal in it real time.. along with solutions to problems how to repair fix service nd all
Viper 487v remote wont work
reprogram the remote start
We have Viper 5301. Has worked fine. Someone used our car and when it was returned the viper doesn't work. When we press unlock, lock or start the top led flashes two or three times (orange) then there is...
Some fixya user told me a website reliable-store it is very good.. I used it to repair my shredder it had some spark issue which wasn't easily fixed. you can go there and try free
2answers
Viper remote starter-
The start/stop 3x thing could be one of a few main issues. You need a bypass module or it needs to be reset. You need to program the tach if you're using it. Make sure with the new models(5101, 5301) it's programmed for auto transmission. The come default for manual transmissions.
Car beeper
follow the instruction in our viper manuel you need to reprogram the system thanks pierre
Top Viper Vehicle Parts & Accessories Experts
oneStan
oneStan
ZJ Limited
ZJ Limited
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
