SOURCE: toddler bed
Here is a website that has the instruction manual in PDF format.
http://common.csnstores.com/common/marketing/baby/delta%20childrens%20products/Toddler%20Bed%20Instruction%20Manual%20(dora).pdf
SOURCE: Cars Toddler Bed problem
mcdevito75 here, Use the contact info in the istruction manual you have, and speak with Disney.
SOURCE: How do I put together the Disney Magic Rise Oven?
I had the same problem. It does in fact 'snap' together, but you will have to put a little umph into to it. Good luck and Merry Christmas!
Remove the tent and poles from the packaging. Select an indoor area with a high ceiling or an outdoor area without overhead obstacles. The poles are not excessively long but they will be difficult to assemble without space.
Lay the Princess tent with the floor on the ground. Pull on each corner to tighten the floor. Assemble the two tent poles by inserting the male sections into the metal ferrules.
Slide one pole through each of the diagonal sleeves. Place the end of each pole in the fabric pockets on the corners. This will flex the poles and raise the tent body.
Place the fabric roof on top of the tent. Attach the hooks on each corner of the roof to the loops on the top of the pole sleeves. The roof fabric will stretch tight and cover the ventilation gap in the tent ceiling.
