Epson STYLUS R230 InkJet Photo Printer Logo
Srabon Mony Posted on Oct 14, 2014
How to solve my missing magenta color
Magenta or black missing my Epson style R230
5 Related Answers
Anonymous
  • 94 Answers
  • Posted on Jun 10, 2008
SOURCE: printing in black & white when color cartridge ran out
One of the possible reason why you can't print black in white because Epson ink jet printers require all of the ink cartridges to have ink in them in order to print any color, black and white, or grayscale images. More than that Epson printers contain a permanent print head that needs to be charged with all colors to work. Even when users are printing black text only, a small amount of color ink is used to keep the print head charged for color printing and prevent air bubbles from entering the color print nozzles which can damage the print head.
Anonymous
  • 54 Answers
  • Posted on Jun 12, 2008
SOURCE: Epson Stylus R230 Light Magenta Not working
Print first a nozzle check pattern, self test which they say. Check your manual for your printer, it should be accessible from that if you dont have any manual, go to the epson website and download a manual. Usually the self test would go like this.
While the printer is turned off, you press and hold down the paper feed button, continue holding it down while turning on the printer. It will print the nozzle check pattern standalone. If you see all the colors then the issue your having is a color management issue, if you do not see the cyan, magenta, yellow, black, light magenta and light cyan from that test; then you will need to do 3 consecutive times of Head Cleaning from the maintenance program in your computer. If you have a windows xp it goes like this.
Click on start go to control panel - printers and faxes -
you right click on your printer icon and select printing prefrences. From there, go to maintenance tab and click head cleaning, go through that cycle 3 consecutive times and see if it improved. Good luck....
aicaxz
Anjazmoro Wicaksono
  • 511 Answers
  • Posted on May 27, 2009
SOURCE: Epson R230 steady 2 red light on.
It may be a general error. It is caused by cartridge error (won't read the chip), cartridge can't move back safely, or "something " slip to the mechanics. If u use the compatible chip (CISS), try to use the original chip first. The last action is turn off the printer for about 1 hour, and turn on back. It's for clearing eprom.
Anonymous
  • Posted on Aug 03, 2009
SOURCE: how to open case epson r230
take a brick and hit on epson, its open
Anonymous
  • 126 Answers
  • Posted on Jul 11, 2011
SOURCE: My Epson R230 printer does print Light magenta and
1. open a document. 2. control-P - shortcut for print. then click properties, click maintenance, then click head cleaning. after this print check pattern. continue doing this until your light magenta and yellow ink gets clearer. if it didn't work replace your light magenta and yellow cartridge.
Epson Stylus R230 Magenta and Light Magenta Not working
try a head clean , you will find the head clean program in .. click open the start bar/go to control panel / open devices and printers/ look for your printer ( epson ) and now RIGHT click on your printer and go down to properties/look for the tab "maintenance" run the head cleaner ( you might have to do it a few times )
My Espon R230 printer has problem with Light Magenta colour, i bought new cartridge but then also light magenta nozzle check is not clear, i think it is printer problem, please help me how to solve it
First you could do a printer test. The printer will print a small pattern with all colours making it possible to check if and if so, what nozzle are blocked. Sometimes the cleaning cycle will help, but sometimes there is just some dirt under the head. Please don't try to remove it with tools if there is something. Just use a thick piece or printing paper to solve that problem. Please check the manual for details. Perhaps the epson site can help you with that:
http://www.epson.com.sg/sites/epson_singapore/support/support.page
How to solve my print color problem
Assuming that you have ink for any color, the problem can either be clogged print-head or an electronic (board) failure no longer controlling a color/colors.
The linked procedure may help:
My printer is not print same color my design printer r230
Buy Cheap printer ink from Peachtreeink.net They are Good Quality printer inks manufacturer with best quality.
Visit Cheap printer ink website at http://peachtreeink.net
My epson r230 is having a problem, the magenta color doesn't appear evenly during nozzle check and when i print picture it doesn't appear nice and clear please help me solve my problem. thank you!
I can't say for sure but it sounds like your print head is permanantly clogged. I avoid Epson because they have a permanent print head unlike Hewlet Packard HP printers. I think there is a solution kit you can buy that runs a solvent through the print heads to clean them out. Look for something like that as a replacement print head typically costs more than a new printer. Hope that helps, Take care.
Epson r230 kalau buat ngeprint warna merah tua gak keluar,padahal selang penuh,bgm?
Sama Gan, printer Epson R230 ane warna Magenta ga keluar saat di Nozzle Chek padahal di status tinta full, udah ane headclen berulang-ulang dan sedot udara pakai suntikan tetep juga gak ke print warna Magenta'nya. Mohon bantuan Agan-Agan yg bisa kasih Solusi? Thx.
Epson R800 Red Color Problem
Actually magenta is the weakest compared to cyan and
yellow using even K3 inks. Now epson is releasing
K3 with vivid magenta ink. Using any color management
I have found it very difficult to reach a real red without
a lot of tweaking in my color profiles. Now it appears
that Epson sees the problem and is changing magenta
out for vivid magenta ink to solve the weak magenta.
4helpful
2answers
2answers
I would recommend cleaning the contacts (brass colored connections) with an eraser if might resolve the issue. It that does not resolve the issue it might be one of two other things. Either the printhead is cloged or the cable to the printerhead is damaged.
Good luck
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
