It appears to be "Locked up" as it has 4 items in queque and no matter what I do it wont print them> Any suggestions?
The print queue is what is locked up. Try deleting the items in the print queue.
Start by pausing the print queue. Then delete the items in the queue one by one.
When you have the last print job in the queue it will probably be jammed up in the transition between the computer and printer. Switch off the printer. This should cause the printer on the computer to become offline.
Try deleting this job abain. If it dissapears then turn the printer back on making sure the computer understands the printer is back online. Then try printing again.
If it does not dissapear then you will need to restart the computer to free up this job. When the computer is back up and running check the print queue again. If the job is gone then turn the printer back on and try printing again. If it is not gone then try once again to delete the print job and it should dissapear this time.
Once the job is gone and the print queue is empty turn the printer back on and make sure the computer understands it is back online again.
SOURCE: Hello, I have HP F4280 and prints Ok but when I
I have the F4283 and the scan button has never worked (I'm on my second). I put the paper in the scanner than start the scan via the solution centre on the pc.
SOURCE: My Dell V505 printer won't
Turn the printer off.
Disconnect the AC power.
On your computer, click Start
Click Control Panel
Click Printers
Select the Dell Printer
Uninstall it
Restart your computer
Turn the printer on
Allow the computer to reinstall the device-device for the printer.
Print a test page.
SOURCE: I've got an hp plotter
Use 1524x5000mm and select remove top bottom white margins from the driver.This should fix the preview problem.
SOURCE: printer claims ink cartridge is expired and won't let me print
Hello, if you change the date on your computer to 3 months previous (say), then reboot, you can probably overcome this temporarily. Obviously, for normal operation it's best to restore the date to current, and only set the date back when you want to print something.Regards,nicam49
SOURCE: my printer reads too many events waiting do not power off lexmark 543dn
If the printer is not updated, please update the firmware. Click on the link to get download the firmware.
http://bitly.com/xHO5Dc
For further assistance, please contact Lexmark Technical Support.
1. Turn Off
printer, cable power still plug in.
2. Press
Stop/Reset button, don't release the button.
3. Press Power
button by holding without release and than release Stop/Reset Button.
4. Press
Stop/Reset button two times (2x) now release the Power Button.
5. Wait until
service mode to zero (0).
6. Turn off
the Printer, cable power still plug in.
7. Press
Stop/Reset button, don't release it.
8. Press Power
button don't release & than release Stop/Release button.
9. Press
Stop/Reset button four times (4x), wait until service mode to "1"
10. Turn off
printer, and loose cable power, wait for one (1) minute.
11. Connect cable power, turn on printer again, now this printer ready to use.
Follow this instruction step by step.
1. Turn Off
2. Press
3. Press Power
4. Press
5. Wait until
6. Turn off
7. Press
8. Press Power
9. Press
10. Turn off
