Main oven stopped working. No light or fan. Clock went out at the same time
Have you checked the power source to the oven? Has the cord come out of the wall plug? Has a circuit breaker tripped? Once the obvious things are checked and proven good will it be necessary to dig into the interior of the appliance.
Testimonial: "Hi many thanks. Have checked these. The fan oven and clock are out however the second oven and HOTPLATES are working."
SOURCE: bosch electric single oven (hbn 4305)
hi there have you cheked that your timer is not set to auto function
SOURCE: Main Oven Issue??
Thank you so much! Holding the two (autocook on and off) buttons together got rid of the A and now the bottom oven works! Great!
SOURCE: belling synergie oven - main oven won't come on.
hi
check the timmer clock is not in auto mode as this will stop the oven from turning on. if clock ok then fault could poss be the thermostat
hope this helps you
regards dan
SOURCE: My GE Oven heating element and timer clock went
Try unplugging the oven and let sit for 10 min. This will reset the curcuit board and reboot the electronics. You may have to pull out the stove o get to the cord.
SOURCE: clock on cooker flashing
Just to let you know that i have solved the problem with my cooker, (clock flashing after electric going off) i held down the cook period button and the end time button, then i was able to reset the clock by pressing the +button.
