SOURCE: toshiba estudio 350 the error
If wait warming is occur on the panel, and it wouldn't change to ready, then fuser unit is the cause. Need to check the themistor and themostat on fuser unit.
SOURCE: Toshiba estudio 166 C44 error code
Hold "0" and "8" while turning on machine.....continue holding until machine enters service mode. Enter "400" press enter. Enter "0" press enter. Power off / on. If code returns, machine needs parts replaced. Do Not keep resetting, may cause damage to Fuser Unit.
SOURCE: toshiba estudio 4511 error code C440
Press 0-8 then enter 400 and make it 0 then press print switch, if doesen't work u have to change thermostar, then if not working change heater, if not then IH board, and the last solution is to change the system board.
SOURCE: We have an Toshiba estudio 205 copier and are
E14 Cassette 2 feeding jam (PFU)
check for pices of paper in the sensor area, if you can not see any you will have to call a tech to check if the paper sensor si not damaged.
SOURCE: I am Engineer of all
You need an update firmware? USB and Jig. Are you a freelancer? or you are working in one company.If your company is connected to TTEC.then ask your boss to download it from web of
TTEC.
