thats called letterbox mode not postage stamp u need to take the tv remote go to menu button and press go to tv settings scroll down to tv display set up ok,select aspect ratio select 16;9 then ok the tv will be full screen
Hi, Turn your TV on, select the menu and see if there is something in picture settings (wide screen or full screen) Try to connect a DVD player using HDMI cable. See if there is any difference.
Some DVD players will also have screen sizing. If nothing helps contact TV repair. Good luck
Can't get full picture ?
If this is for running a dvd if it is not a
full screen version of the dvd then you
will not get it.
If it is widescreen addition you will get the
black bars at the top and bottom.
If you can't get full screen in normal mode a
few things could cause this.
One if your running from your "say" direct tv box.
You will need to try your Format button...second
button on the left of the remote.
Second you could try the restore settings on your
tv, it will restore the settings to the manufacturer's
original settings.
Keep in mind that not all tv channels are full screen.
Example: If I watch nfl gameday in HD it is full screen.
If I select the same program but, not in HD the screen
is smaller. thing it goes to a 4:3 aspect ration..
Switch back to HD and it's full screen again.
it sounds like you have horizontal colapse a very complect repair try hitting the tv if the screen comes up full picture then its a dry joint if not there is an ic or power fault toss it
