Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard Logo
A
Anonymous Posted on Oct 14, 2014
SET JUMPERS ON 848P-A REV 2.0
MOTHERBOARD JUMPER SETTINGS ON 848P-A REV 2.0 15-875-01200 848P-A 253 WINBOND
Lars Olsson
Level 3:
Brigadier General:
  • Intel Master 3,400 Answers
  • Posted on Oct 14, 2014
Lars Olsson
Intel Master
Level 3:
Brigadier General:
Answers
3400
Questions
Helped
1048929
Points
10330
READ THE MANUAL,IF LOST.GO TO THE MANUFACTURERS
SITE AND DOWNLOAD A NEW ONE.
My motherboard (intel DG41WV) is starting but not giving output to screen. I have cheked cables sokets. Even i have cheked to other screen. but problem is still. all peripherals (fan, cd-rom...etc) are...
Jumpers:
Motherboard installed in computer case;
A) Keyboard Jumper Block
3-pin jumper block, Top of motherboard/ left side. Near the mounting hole, and 4-pin ATX +12 Volt power cable connector,
GENERAL example of a 4-pin ATX +12 Volt power cable, and it's respective connector on the motherboard,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
[ This power cable MUST be plugged into the motherboard.
It is power for the Intel processor ]
3-pin jumper block.
Starting at the TOP coming down;
Pins 3, 2 and 1.
Jumper cap should be on Pins 2 and 3.
(Enables the Keyboard wake-up feature. Factory default setting is Enabled. Pins 2 and 3)
B) Clear CMOS Jumper Block.
BOTTOM right corner of motherboard. 3-pin jumper block.
It is to the Left of the bottom/left SATA connector.
It is immediately to the Right of the motherboard mounting hole.
Starting at the Top, and going down towards the bottom edge of the motherboard;
Pins 3, 2, and 1.
Jumper cap should be on Pins 1 and 2.
When you changed the SMPS, do you KNOW for a fact it is a good one?
Did you plug the 4-pin ATX +12 Volt power cable, into the motherboard?
What COMS setting/s did you change?
I would go back into BIOS Setup, and set that menu screen back to the factory default settings.
[ Load Optimal Defaults ]
BIOS Settings Glossary,
http://download.intel.com/support/motherboards/desktop/sb/biosglossary_v18.pdf
Regards,
joecoolvette
[Motherboard manual - http://www.intel.com/support/motherboards/desktop/dg41wv/sb/CS-031417.htm
1helpful
Mk40vn no beep no powerled some hdd led some cd led after reset cmos jumper in right position no other jumpers are set on board i have no manual for jumper settings please help me susanne
in some motherboard when you change the c mos jumper the motherboard doesn't switch on change the pin to 1 and 2 normally which is c mos normal and 2 and 3 is to clear c mos you will see marking of all the jumpers in the motherboard set the pin correct to normal and also remove the power connector from the motherboard and short the green and the black wire and see whether the smps works if not working change them
Jumper mapping for via5000 epia rev.E
BIOS jumper (1x1:3) is next to the CMOS battery east and slightly south of center, Freq MHz jumpers (4 x1:2) are on the north side just west of the DIMM banks, front panel etc. jumpers (multiblock + 2x1:2) are in the South-West corner.
Reset power on password jumper
Motherboard Jumpers:
Some, but not all, motherboard manufacturers provide a set of three jumpers on their motherboards that provide you with the ability to clear the Bios/CMOS settings, thereby allowing them to be reset. For the most part this is used when the Bios/CMOS data becomes scrambled and you need to clear the Bios/CMOS in order to return the computer to a functional state. This same procedure, however, can be used to clear passwords from the Bios/CMOS setup. Typically a jumper will be found across pins #1 and #2 as the default position, and by shutting the computer down, unplugging the power cord and then moving the jumper so that it is across pins #2 and #3 will clear the Bios/CMOS settings.
Here's an example of a Supermicro PIIISEA motherboard.
piiisea_jump.jpgAs you can see from the picture, we have added two small red arrows. The arrow to the left denotes the location of the "Clear CMOS" jumpers, while the red arrow to the right denotes the location of the CMOS battery.
Here are the procedures if the jumpers are present on the motherboard:
  • Locate, if possible, the instruction booklet for your motherboard. If you cannot locate the booklet, then user the motherboard references on this site to locate the manufacturer and see if a manual is available there. You may also want to closely examine the motherboard itself.
  • Shut down your computer and disconnect the power plug.
  • Now identify where the jumpers are located, then check the present pin location and the location of the jumper on those pins to determine their default location. As an example, the default location on the above motherboard is to have the jumper across pins #1 and #2. Write it down!
  • Next, move the jumpers from the their default location (Example: from across pins #1 and #2 as above) and then place the jumper across pins #2 and #3.
  • Leave the jumper in place for 20 to 30 seconds and then return it to its default location.
  • Now plug the power cord back in and restart the computer.
  • When the computer begins it's startup (boot) process, tap the DEL, F10 or F1 key, (whichever is appropriate for your computer) to get into the Bios/CMOS setup. If you need more detailed information as to how to get to the Bios/CMOS setup, follow this link. Bios Basics
  • Once into the Bios/CMOS setup, look for a section or area to set the Bios/CMOS to its default settings. This will return the motherboard to either its basic or optimum settings depending upon the motherboard manufacturers settings. You will then need to verify certain settings, such a CPU and memory as well as hard drive type and size recognition. If you need more information regarding these settings, follow either of these links: For an AMI Bios or for an Award Bios.
  • After making any final adjustments, save your settings and restart the computer. The Bios password should be gone and the Bios set to its optimum settings.
If the "Clear CMOS" jumpers are not present or not available:
The procedures for clearing a Bios/CMOS without jumpers is essentially the same as those given above when they are present, it just takes a little more effort.
  • Shut down the computer and disconnect the power plug.
  • Locate, if possible, the instruction booklet for your motherboard. If you cannot locate the booklet, then use the motherboard references on this site to locate the manufacturer and see if a manual is available there. You may also want to closely examine the motherboard itself.
  • Now identify where the battery is located on the motherboard. It will be approximately 1/2 inch in diameter.
  • Normally these batteries are held into place with one or more small clips over the face of the battery. Carefully lift the battery out of its socket and set it aside. Note: Some batteries are actually soldered to the motherboard, so take that into consideration and be careful.
  • Leave the battery our of the computer for about 20 to 30 minutes and then return it to its socket.
How do you get the password off of the
There are two ways to reset the boot or the bios password:
1.By removing the CMOS battery
You have to shut down the computer , disconnect the power plug and open up the unit and locate the CMOS battery ( which usually looks like a coin) . Carefully lift the battery out of its socket and set it aside.Leave the battery our of the computer for about 20 to 30 minutes and then return it to its socket. Now plug the power cord back in and restart the computer.
It'll reset all BIOS settings as well as the password and you'll need to re-enter all settings.
2. By using the motherboard jumper
Shut down your computer and disconnect the power plug. Identify where the jumpers are located. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc. Then check the present pin location and the location of the jumper on those pins to determine their default location. As an example, the default location on the above motherboard is to have the jumper across pins #1 and #2. Write it down! Next, move the jumpers from the their default location (Example: from across pins #1 and #2 as above) and then place the jumper across pins #2 and #3.Leave the jumper in place for 20 to 30 seconds and then return it to its default location.Now plug the power cord back in and restart the computer.Next, move the jumpers from the their default location (Example: from across pins #1 and #2 as above) and then place the jumper across pins #2 and #3.Leave the jumper in place for 20 to 30 seconds and then return it to its default location.Now plug the power cord back in and restart the computer.
For detailed instructions and snapshots u can check up this link :
http://www.askvg.com/how-to-reset-remove-bypass-a-bios-or-cmos-password/
1helpful
2answers
I NEED THE JUMPER SETTINGS FOR MICRO STAR MS-6533E MOTHERBOARD. THANS FOR THE HELP!
why are u trying to set the jumpers ? i should have thank u if u add some more details. all the jumpers onboard have their own purpose. look carefully on ur mainboard, u'll see the jumpers with their distinct labels.
Jumper settings for the Masscool XWT-PCIE10
Do you remember the default jumper settings? they're set to external ports' usage.
Have a good day.
1helpful
2answers
MSI 845GE MAX L MOTHERBOARD JUMPER SETTINGS
Hello!
If the motherboard is new or you never set any jumper setting or you did not interfere any connection seeting their then you yo did not need jumper setting to seat the CPU.
The CPU you are going to use is very compatible in your mainboard so do not worry about the setting.
more about your setting click here for the usermanual of your board.
hope this help, melnavz
Top Intel Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
