Amazon Kindle Fire HD Logo
A
Anonymous Posted on Oct 14, 2014
What do I do if my Kindle fire won't charge?
It won't charge.
honey
Level 3:
Master:
  • Amazon Master 262 Answers
  • Posted on Jan 05, 2018
honey
Amazon Master
Level 3:
Master:
Answers
262
Questions
Helped
320346
Points
1535
I have faced the same issue with my kindle as well Give a call on this number(877-330-0887) Kindle Technical Support Registration 877 690 9305
steve morris
Level 3:
  • Master 1,675 Answers
  • Posted on Jan 11, 2015
steve morris
Master
Level 3:
Answers
1675
Questions
0
Helped
653580
Points
5484
Hi You can try and reset it click link it will show you how to hope this helps How to Reset Kindle
2 Related Answers
Anonymous
  • 4961 Answers
  • Posted on May 15, 2012
SOURCE: `kindle fire
Sounds like your power cord is dead and that it's not charging. If it's new bring it back to the store you bought it from and get a new one.
Mike F
  • 59 Answers
  • Posted on Jul 17, 2013
SOURCE: kindle fire won't charge
You may need a new power cord or it is possible that your Kindle Fire's battery has died. If you noticed the battery life diminishing before it wouldn't charge this may be the case. Here is a site that has replacement batteries for the Kindle Fire:
3555A2L Battery for Amazon Kindle Fire D01400
Important tips to fix the problem of Kindle Fire won't turn on?
Press and holding down the power button for 20 seconds or more. Then turn the device back on by hitting the power button again. If this doesn't work the first time, you can try holding the button down for 30 seconds or more. Most of the time, this will be all you have to do to make the Kindle Fire work again.Oct. 11, 2014
SOLVED: My kindle won't turn on. Is it the battery? - Kindle ...
How to Fix a Kindle Fire That Won't Turn On - Lifewire
www.lifewire.com > kindle-fire-wont-turn-on-or-charg...
May 26, 2020 - Perform a soft reset. A soft reset resolves many common issues without affecting any data on the device. Press and hold the Power button for 40 seconds, then release. The charge indicator light should turn on after several seconds, and then the Kindle Fire should reboot.
Amazon Fire Won't Start - Technipages
www.technipages.com > amazon-fire-wont-start
Fix an Amazon Fire that Won't Start. Hold Power Button. Ensure that you are holding down the "Power" button for at least 5 seconds to power it on normally. Charge Using AC Adapter. Ensure that the Amazon Fire has a charged battery. Hold "Volume Down" While Powering On. Restore Latest Software.
VIDEOS
https://www.google.com/search?q=Kindle+Fire+won%27t+turn+on
2answers
My kindle won't charge. I have tried 3 different chargers.
Lillian, May have to try hard reset or possibly repair charge port to get battery to start charging. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
My Kindle won charge
Kindle Wont Start or Charge How to Reset Kindle
Troubleshooting Kindle Fire That Won Charge
Kindle Fire Won Charge Fix
2answers
Won't take a charge.
Armend, Could be a bad charging port. Press and hold on button for 15-20 seconds a couple times to see if it will reset and power up before trying anything else. Check the attached links, videos,instruction and guides on kindle charging problems. Good luck
12 major Kindle Fire problems and how to fix them
Reset Kindle Fire When it Won Turn on or Charge
2answers
Fully charged. Why doesn't it turn on?
Ruby, try pressing and holding on button or you will have to reset.
My kindle won turn on
My kindle won turn on Is it the battery Kindle Fire HD
Amazon Kindle Won Charge Quick Fixes
Kindle will not shut off-goes to shut off or cancel but wont move. doesnt charge well-doesnt always hold charge
Patricia, Using the power switch, you can forcibly reset your Kindle device. This reset will shut down the Kindle without accessing the shutdown command from within the Kindle's operating system, a particularly useful tool when dealing with a frozen Kindle. To initiate a hard shutdown, Kindle disconnect from its charger, slide and hold the power switch for about 20 seconds. This will force the Kindle to shut down, now it can be restarted normally.
Check links below for charging problems.
Kindle Fire not charging
9 common problems with the Kindle Fire HD and how to fix them
3answers
I can turn my kindle on but can't get any thing else to work.
Reset Kindle Fire When it Won't Turn on or Charge
www.lovemyfire.com > Kindle Fire Problems
However, sometimes when it locks up you can't tell because the screen goes dark, either ... it's already on but is locked up and thus won't charge or work properly. ... 15 minutes to make sure it gets enough charge, and then try turning it on again. ... If this tip (or anything else on my site) helps solve your Kindle Fire problem ...
Amazon.com: Customer Discussions: My Kindle won't charge
www.amazon.com/forum/kindle?_encoding...
Amazon.com, Inc.Jan 3, 2013 - If you can't see a Contact Us button on this page, then go to .... What canI do? I sent an e-mail to Amazon but have not heard anything. My Kindle is frozen and won't ...
Mar 31, 2014
How to unlock a Kindle. Lock won ...
Jan 27, 2014
Kindle paperwhite won't turn on
Nov 6, 2013
My kindle won't turn on....green ...
Dec 12, 2011
More results from www.amazon.com
2helpful
4answers
The kindle won't turn on
It is possible that your Kindle Fire's battery has died. If you noticed the battery life diminishing before it wouldn't turn on at all this may be the case. Here is a site that has replacement batteries for the Kindle Fire:
2answers
1helpful
4answers
Top Amazon Tablets & eReaders Experts
Grand Canyon Tech
Grand Canyon Tech
Jennifer Rock
Jennifer Rock
Are you an Amazon Tablet and eReader Expert? Answer questions, earn points and help others
