Rio Forge Sport Digital Media Player Logo
Posted on Nov 11, 2007
RIO FORGE 256
When i turn the mp3 on it says ..internal memory problem ...reformat with usb.
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Nov 11, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
200
Points
I had exactly same trouble - at least twice..
One time a battery switch and drain for at least 10 min fixed it.
another time I reinstalled firmware...
No big deal..
2helpful
My rio forge player is showing "upgrader"
When mine did this it meant the firmware inside had gotten corrupted. It started working again when I reinstalled the firmware. The official firmware is available at the official website, and wikipedia promotes an unofficial firmware that provides more features.
For either of them, plug the unit into the USB port of your computer, then run the utility to upgrade the your Forge.
(Eventually, my Forge's internal memory storage died - it still play music from card memory, but every time I turn it on I have tell it my language is english etc.)
I hope that helps.
3answers
Rio Forge 256Mb Mp3 Player
was there any cd given along with the purchase of this player???????
2answers
Rio Forge 256 mp3 player
you should be able to access the menu on the mp3 this should allow you to select the music setting this should get you back on to the recorded one hope this is some help for you..............................
Rio Forge 256 MB
Try hooking the player to your computer and reformat the memory in the player. Just like you would format a disk.
Kenny
1helpful
2 probs
Press the MENU and turn it on, as soon as the word RIO shows on the screen release the power button but do not release the MENU button until it says upgrading
Plug the USB cord to it and install Rio Forge Firmware_120
Turn the mp3 off then on normally
Put the music back on your mp3 and it SHOULD be fixed. but your music will be gone..
hope this helps,
trin
Rio 512 mp3 player
You need to connect the Rio to a PC and then use the Windows Explorer format disk feature to reformat the Forge's flash memory as a FAT32 partition.
1helpful
10answers
I had the same problem and, after scouring the internet in search of a solution, found nothing. So I started messing around with things. About 5 minutes ago I came up with something that worked for me! I'm still in 'testing' mode but it's playing some ACDC now so I'm happy. ;-)
My first step was to download a firmware 'update'. I'm not sure if it's newer or older than the firmware that I already had in there, but it works so what the heck. It's version 1.16 and is available for download here:
http://www.opendrivers.com/downloaddriverlink.php
Filename is 'RioForgeFlash_116.exe'
To update the firmware, I connected the player via the USB cable. It will power itself up automatically - make sure you have a fresh set of batteries in it. Once it powers up, turn it off but leave it plugged in via USB. Then, power it up again but press and hold the mode button (the small button on the face, to the left of the main navigation buttons. It's the one you use to select different play modes etc.). It will power up and display 'UPGRADER'. From this mode, run the udate file (RioForgeFlash_116.exe); it will update the firmware in the Forge.
Once completed, my Forge interacted normally with the Rio Music Manager and I was able to upload music to it again. I did lose all the music that was in there and on the storage card, but that's better than having a useless MP3 player!
Best of luck!
3helpful
Internal memory unknown format
Turn it on holding the MENU button, connect the usb cable and update the firmware that u can download from www.rioaudio.com, that will fix it.
5helpful
3answers
Rio forge 256 MB mp3 player
This happened to my player also. To fix it, you have to go to the rio website and download the most recent firmware for whatever model mp3 player you have. I went to: http://www.digitalnetworksna.com/support/rio/product.asp?model=265&SKU=90260558) Next install. Plug in your player to your USB to your computer - BUT (and here's the important part) you need to hold down the menu key while plugging it in. Keep holding until it powers up AND the word "UPGRADER" shows on the screen. Now, run the firmware upgrade program and follow the directions and it will see your player and upgrade the firmware (yes, even if it's the same firmware version.) You'll have to run the .exe file to get the upgrades onto your player. Unplug the player and it should be like new!
1helpful
Rio 258 cannot connect to computer
1. go to http://www.digitalnetworksna.com/support/r....asp?prodID=213 and download update 1.33 2. install update in C:\RioForge\Flash133 3. run RioForgeFlash_133.exe from C:\RioForge\Flash133 4. press Rio Forge menu button and turn the unit on. "upgrader" will appear on screen. 5. plug USB cable to RioForge. 6. click "next" on Rio Upgrade Wizard. Wizard will detect your player. Select and click "next". Upgrade will take place. 7. Unplug Rio Forge from USB and turn it on. Voil?!
Top Rio Audio Players & Recorders Experts
Mohammad Abumuailek
Mohammad Abumuailek
ADMIN Andrew
ADMIN Andrew
Are you a Rio Audio Player and Recorder Expert? Answer questions, earn points and help others
