If you remove the handle, you will notice there is one larger black Phillips screw under the black plastic strip.
Engage the wheels and loosen that screw.
Slide the lower handle part back and forth and you will notice the wheels will reverse and go forward again.
Find the position where the wheels lock and unlock for you, and tighten that one screw again.
It does not take very much adjustment to make that system engage so do it in small increments.
You will see what I mean when you unlock that screw and slide the lower handle just a tad , but the wheels must be in the engaged position in order to adjust it properly.
would think its damaged the motor. if it was plugged in and running at the time it may off blown the fuse. if the housing gets jolted it could brake the motor supports and bend the vacuum chamber stopping the fan from going round,
Vehicle and brake manufacturers generally say brake pads need changing at 3 mm and some which aren't very thick when new 2 mm is the recommended change point.
Vehicle repairers tend to use any excuse to make a little more profit but in the case of a car that does a high mileage which they are unlikely to see for a year does rather justify a change at 6 mm, though strictly they should obtain prior permission to do so.
I have experienced brake fade twice and both times was when I replaced brake pads shortly before holidaying in a mountainous region. Having learned my lesson I would now holiday with well-bedded brakes and change them when I returned home. Brake fade is definitely not funny especially when driving an auto.
If you are just starting to sew and do not have good foot control look into getting a d/c motor they are about $120 and you can turn the speed of motor up or down
1) you need a little tight the belt, with the bolts of motor. 2) you must shure if the belt if NOT large or short( in both cases the rollers will NOT run. can be slip. or too TIGHT. and BRAKE the motor. 3) the motor you must test for brush, switch, or open winding. 4) put a little lube in the extreme of shaft rollers,see by turning at hand if they run of course unplugged the power cord. God bless you
The ABS module has a history of wearing out on VWs. Nothing wrong with the brakes themselves, but the ABS module would need to be replaced to stop the lights coming on... but the problem is a new ABS module can be very expensive for a new one (~$900) or you can sometimes get a rebuilt one for a couple of hundred dollars.
While the ABS is broken, your car has regular normal brakes like cars have had for decades.
well will the brushes turn freely as they run in bearings if its got wool of cotton raped around the side of the brushs that will make them tight to turn and will brake every belt you put on it, in a flash,,,
the other thing that causes the drive belts to snap is the motor spindel is getting very hot and this lowers the life of the belts as well, every thing must turn freely, its only a big rubber band at the end of the day but they are pricy though
