SOURCE: My serger
Self threading is perhaps not exactly correct, however there is a guide with an armature to release the guide to enable easy access........have a look in you manual
Also take a look at this image and move the lever to use it.....all will be easier to see with the needle plate off ....until you become familiar with the operation
SOURCE: Janome MyLock 644D
Yes, the model I used had a self threading lower looper. Just put the thread into the guide and flick the switch
SOURCE: janome mylock 234 d
It may be rusted or a looper may be bent. Take it into a sewing machine dealer for service/repair.
SOURCE: how to set the needle plate setting nob on the janome mylock 504d overlocker
Push blade from right to disengage...slide roll hem ****** forward...reverse operation to return to ordinary sewing.
It is covered in the manual, do you need one ??
SOURCE: need to place the needle plate setting knob back
here is a link for parts for the machine and also a manual for the
machine
http://www.sewingpartsonline.com/Janome-644D-Sewing-Machine-Parts.aspx
