Where is the recal button on the transcriber so I can hear a repeat of the last few words I left off on
SOURCE: I have a Lanier Voicewriter
Pull up Job List, find the dictation and assign it to a specific person. Then you can listen to it. It will beep unless your feet are on the pedals.
I don't think that's possible, the minicassette won't fit between the spool spindles. You may be able to use a minicassette player, and route its output to the full-sized cassette recorder, though, or to a little transmitter that broadcasts to a matching receiver in the full-sized cassette player.
To recall an error code,
Wake the machine by pressing any button Wait
5 seconds Press and hold the Start and Pause Cancel buttons
simultaneously Ail LEDs will go blank and after a few seconds the control will signal the
stored code using audible beeps and blinking LEDs. The control will repeatedly
signal the code, as long as the Start and Pause Cancel buttons are
pressed. A two-second pause between repeats affords you the ability to make
accurate counts to identify the correct error codes. you
may also have a code such as E47 or E24 etc.. Comme back with the code and I will explain what is the meaning of the code
Wait 5 seconds
Press and hold the Start and Pause Cancel buttons simultaneously
Ail LEDs will go blank and after a few seconds the control will signal the stored code using audible beeps and blinking LEDs. The control will repeatedly signal the code, as long as the Start and Pause Cancel buttons are pressed.
A two-second pause between repeats affords you the ability to make accurate counts to identify the correct error codes.
you may also have a code such as E47 or E24 etc..
Wait 5 seconds
As long as the buttons are held, the failure code will appear in the display as an E followed by two numbers, a number and a letter or two letters, please post back with the error code for further assistance.
Hello really simple on the front small door is a switch
that say SPK and MIC move to MIC
Hello is possible that your power supply is bad or may be just the jack on the unit you have two options you can Send an email to [email protected] or call (800) 644-9525. Please indicate model, serial and detailed description of problem or try a new power supply at http://www.tvps.com/Products/Lanier-APS-160-Desktop-Power-Supply---New__LA-APS160.aspx
