Garden Logo
A
Anonymous Posted on Oct 13, 2014
HOW DO YOU ADJUST CARB ON STHIL CHAIN SAW - Garden
Les Page
Level 2:
Champion:
New Friend:
  • Expert 256 Answers
  • Posted on Oct 18, 2014
Les Page
Expert
Level 2:
Champion:
New Friend:
Answers
256
Questions
Helped
72035
Points
275
Start by turning adjustment screws in. turn low speed out one turn and the high side 3/4 turn. start engine and adjust accordingly. the one turn and 3/4 turn are the starting point. saw should start at these settings and then you can fine tune. without knowing your elevation I can't give you the number of turns .
5 Related Answers
A
Anonymous
  • Posted on Sep 21, 2008
SOURCE: how to adjust carb. settings on a McCulloch Pro Mac 610 chain saw
turn both jets in untill snug (don't force) turn out ccw one full turn. increase by 1/8 turns untill set proper. should be between 1 1/4 and 1 1/2 normally. good luck. be safe.
Lee Glascock
  • 384 Answers
  • Posted on May 12, 2009
SOURCE: I have a Homelite model 20 chain saw. It will
on your machine may be on the side of it that led into the carb should have H for high L low L is for the idle H is for all out ball to the wall you will need a small long screw flat head . put in the H ,turn out for more gas in for less good luck
Anonymous
  • 169 Answers
  • Posted on Nov 19, 2009
SOURCE: how to adjust a carb on a stihl chain saw
deprnding on model. start with screws lightly bottomed. turn both screws out 1.5 turns
Anonymous
  • 345 Answers
  • Posted on Apr 28, 2010
SOURCE: carb rpl and adjustment
you have 2 screws marked H and L. With the engine running, turn the L (low) screw for best idle. Then for the H (high) screw, Hold at full throttle, turn screw, and listen for smothest and fastest revs.
Anonymous
  • Posted on Jun 11, 2010
SOURCE: poulan chain saw will not stay running after i sta...
a good starting point is the low speed screw at 1 3/4 turns and the high side at 1 1/2 turns. Hope it helps
How to change chain tensioner on stihl ms 290 farmboss chainsaw
sthil ms 290 chain saw 9-10-12 - YouTube
? 11:18
https://www.youtube.com/watch?v=-xJAcXZqeog
Sep 10, 2012 - Uploaded by skidoo849
sthil chain saw 9-10-12. ... my 2012 STIHL MS 290 FARM BOSS CHAIN SAW WITH A 16'IN BAR. - Duration: 34:11. MRJOHNDEERE3720.
How To Adjust Your STIHL Saw Chain - YouTube
? 7:21
https://www.youtube.com/watch?v=dZq7ZDBx4iA
Dec 4, 2012 - Uploaded by STIHL USA
Learn the differences in adjusting a cold chain vs.a recently used chai. ... Also learn about the STIHL Quick Chain Adjustment feature found on certain STIHL chain saw models. ... Stihl MS290 Farmboss Discussion - Duration: 5:37. ... How to Replace the Bar & Chain Oil Pump Worm Gear on a Stihl MS 029 ...
[PDF]STIHL MS 290, 310, 390
www.stihlusa.com/WebContent/.../MS290_310_390_Manual.pdf
StihlInstruction Manual - improper use can cause serious or fatal injury. MS 290. Warning! .... engineering changes and improvements ... When using a chain saw for.
Chain Tensioner Adjuster for Stihl Chainsaw MS290 MS39
How to stop sawdust from coming into the carburetor section and how to adjust the chain oiler. chain seems dry.
Check to ensure the oil opening on the side of the saw housing is not plugged as well as the matching oil groove in the guide bar first. Turn the saw upside down and see if there is a + and a - sign near the sprocket on the bottom. If so, turning towards the + increases flow. Most new small saws oilers are non-adjustable.
Sthil 011 chain saw flooding has new carb
may be new carb but the main thing in flooding is that the float is getting stuck or has crack in it...Or second thing is that the needle valve has a piece of trash dirt causing it to stay open..
Jul 24, 2014 • Garden
Adjust carb on a sthil 011
Adjust the carb using the two tuning screws marked H & L. The other one adjusts the idle speed 'tick over'
Working on sthil fs74 weedaeter. redoing carb need to know order of gaskets to double check myself. cant seem to get it going 100%.starts good but doesnt perform so well so decided to clean carb . replaced...
Go to: http://www.drystacked.com for a 12 page article on Walbro brand carburetor theory and troubleshooting. This information applies to other brands as well. Check the muffler for plugging due to carbon build-up. Check the carburetor to cylinder gaskets and heat insulator for damage or plugging of the impulse passage. The engine should 4-stroke lightly when running at speed unloaded, but immediately 2-stroke when trimming. Adjust the H jet needle somewhat to achieve this. Make sure the fuel mix is fresh and using chain saw oil only at 50:1 ratio. Make sure the lower chamber diaphragm in the carburetor is flexible with no holes or cracks. Hope this helps!
Aug 07, 2010 • Garden
Sthil chainsaw: the saw saw starts no problem, then bogs down and dies. replaced spark plug, fiddled with high and low, but still no joy?
You probably have a tiny hole in the carb diaphram or the needle under the diaphram has debris in the seat. With out a model number we can not give you exact parts information.
Check fuel flow to the carb from the tank. If it does not flow freely then either the tank exit hole is clogged or the hose has been pinched / collapsed.
If you go messing with the diaphram do NOT adjust the float on the back side unless you absolutely have to. If you moved H & L jets... start over 1.25 to 1.5 turns from closed after repairs.
Thanks for using FixYa.
Kelly
Apr 12, 2010 • Garden
2helpful
I have a Husqvarna 240 Chain saw. It hasn't been used that much. It is very difficult to start. When running it is a great saw. Runs well under power, nice saw for limbing. The book says to adjust carb use...
Before you adjust the screw, try either, opening or closing the gap on the plug.This will adjust the timing, ever so slightly.
The other choice is to adjust the space betwen the contact, and the magneto.
It is very rare indeed, that the screws on the carb require adjustment.
That should sort it out.
Idle is off??
hi leobowdy
disassembly the carb and carefully clean it.Check the air filter,the fuel line and fuel filter,check the needle,lever,small spring and the screen filter from the carb.Check the sparkplug.
high speed H=2 turns,low speed L=2 1/2 turns,adjust T
When chain saw starts adjust H,L and T accordingly.
cheers savumihai71.
Top Garden Experts
Jay Finke
Jay Finke
john h
