You might want to make sure the HDMI cable is fully plugged at both ends of the cable and try a new HDMI cable. A marginal cable will occasionally drop out the picture.
you could try watching videos from these guys https://www.youtube.com/channel/UCGfTWLdZHHmhtb-qUb5vb2Q but as far as I can remember the thick white one goes
on last then the screen, just make sure you have the ribbon connectors fully in position before you lock them into place
Select the input channel for your Fire TV - Turn on your TV and select the input channel for the HDMI port you used to connect your Fire TV. You should then see a loading screen with the Amazon Fire TV logo 4.
To pettinabatem
I am having a shutdown problem with a Panasonic TC-32LX50. Initially when pressing the on switch, you see for 1 second a right half white screen (the left side of the screen remains black) and the TV turns off and the LED flashes 1 time. I did a T-Con cable check (based on the half white screen) and indeed this went away. Got backlight (full screen and no half white screen anymore). But still the TV shuts down after 1 second and the Red front LED flashes one time. Since this code is also illustrating a "dg board, (stv 5v sense time out)" problem in this unit, I was wondering if indeed you have encountered a defective DG board with yours. I am enclining towards a defective Power supply board.
TV turns on but doesn't stay on goes in and out then blank screen. LED light stays on during the entire time
your problem is called hunting
you can check power supply of your tv .It common problem in Philips T.V.
Thanks
