Miele Novotronic Premier 500 Front Load Washer Logo
A
Anonymous Posted on Oct 13, 2014
Rinses light flashing fast and wont drain drum and finish wash
Fairly old well used washing machine wont finish hot wash cycle rinses light flashes rapidly and it wont drain
Gerry Harvey
Level 3:
Genius:
  • Miele Master 1,482 Answers
  • Posted on Oct 14, 2014
Gerry Harvey
Miele Master
Level 3:
Genius:
Answers
1482
Questions
0
Helped
378792
Points
4533
Try checking the filter for a blockage or pump being jammed with a button , disconnect drain hose at sink hold a few feet off ground over a bucket should pump/ flow quite freely if not then check filter and pump. good luck
2 Related Answers
Anonymous
  • Posted on Aug 07, 2008
SOURCE: Washing machine problem
my w830 is doing exactly the same thing.
I am usually pretty good at fixing these sort of things so if/when I solve it I will post back here.
I think it is a motor fault - most likely the motor brushes are worn out.
richroth
Richard Roth
  • 9472 Answers
  • Posted on Nov 24, 2012
SOURCE: whilst on wash cycle, made a very loud noise, stopped working, flashing drain/spin, now drum wont work on any cycle, will fill and drain
What is the model number of your unit?
1helpful
My Midea front loader won't spin. HELP!
There are a few potential causes for your Midea front loader washing machine not spinning. Some possible reasons include:
  • Overloading: If the machine is overfilled with clothes, it may not be able to spin properly. Try removing some of the clothes and running the spin cycle again.
  • Belt problem: The belt that connects the motor to the drum may be loose or damaged, preventing the drum from spinning.
  • Drainage issue: If the machine is not draining properly, the spin cycle may not be able to begin. Check to make sure the drain hose is not clogged and that the pump is functioning properly.
  • Control Board problem: The control board is responsible for controlling the machine's functions. If it is malfunctioning, it may prevent the machine from spinning.
  • Lid switch: The lid switch is responsible for detecting if the lid is open or closed. If the lid switch is faulty, the machine may not spin.
It's best to check the owner's manual for troubleshooting steps specific to your washing machine, or contact the manufacturer for further assistance. If the problem persists, it is advisable to get it checked by a professional technician.
Start matsui washing machine
Check the washer drain hose for clogs.
2answers
Simpson eziset 550 stops at rinse cycle, light flashing
I had the same problem before, but removing the kink in drain hose does the trick. Maybe yours is more complicated but try it.
4helpful
We have a Whirlpool 7KG frontloader washing machine (6th sense) model AWM8121. The problem is that the door light is flashing, the cycle has stopped at rinse (rinse light is on) and the machine is not...
We have an awm8121 and there seems to be a fault on the Spin cycle indicators with th 0 RPM and the 800 RPM flashing..
We can't seem to get the frontloader to finish the drain cycle and continue into the next was.
The last load of washing was still saturated when we managed to open the door.
1helpful
My washing machine fisher and paykel MW 511 will wash fine but when it gets to the rinse cycle it stops. The lights remain the same (no flashing or beeping) and the motor smells hot. It starts again after...
You have a restriction in your drain line or pump. Also you could have a pump going out. It will smell like a bad motor. So check for a restriction first.
Hotpoint wd44d wash/dryer wont finish a wash nor wont pump out
there may be something stuck in the pump itself. hairgrips and brawires are a common find.
2answers
Washing machine
bottom right corner behind the little door
33helpful
2answers
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Top Miele Washing Machines Experts
Paul Carew
vince
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
