2013 Nissan Rogue Logo
Peter Skroback Posted on Oct 13, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is the emergency flasher relay located on 2013 Rogue?
Where is thhe emergency flasher located on a 2013 Nissan Rogue?
Stan Ford
Level 3:
Genius:
  • Nissan Master 3,131 Answers
  • Posted on Oct 14, 2014
Stan Ford
Nissan Master
Level 3:
Genius:
Answers
3131
Questions
Helped
905027
Points
9078
It is along side the turning flasher unit under the dash. best way to find it , turn on turning signal unit and follow clicking noise.
Rich Hines
Level 2:
New Friend:
  • Expert 27 Answers
  • Posted on Oct 13, 2014
Rich Hines
Expert
Level 2:
New Friend:
Answers
27
Questions
0
Helped
12043
Points
100
Here is what the service manual says. Looks like it is not a flasher relay but a function of the body control module.
TURN SIGNAL AND HAZARD WARNING LAMP SYSTEMSystem Description OUTLINE Turn signal lamp and the hazard warning lamp is controlled by combination switch reading function and the flasher control function of BCM.
TURN SIGNAL LAMP OPERATION - BCM detects the combination switch condition by the combination switch reading function. - BCM supplies voltage to the right (left) turn signal lamp circuit when the ignition switch is turned ON and the turn signal switch is in the right (left) position. BCM blinks the turn signal lamp.
HAZARD WARNING LAMP OPERATION BCM supplies voltage to both turn signal lamp circuit when the hazard switch is turned ON. BCM blinks the hazard warning lamp.
TURN SIGNAL INDICATOR LAMP AND TURN SIGNAL SOUND OPERATION - BCM transmits the turn indicator signal to the combination meter with CAN communication while the turn signal lamp and the hazard warning lamp are operating. - Combination meter outputs the turn signal sound with the integrated buzzer while blinking the turn signal indicator lamp according to the turn indicator signal.
HIGH FLASHER OPERATION (FAIL-SAFE) - BCM detects the turn signal lamp circuit status by the terminal current value. - BCM increases the turn signal lamp blinking speed if the bulb or harness open is detected with the turn signal lamp operating. NOTE: The blinking speed is normal while operating the hazard warning lamp.
5 Related Answers
Anonymous
  • 5158 Answers
  • Posted on Feb 02, 2009
SOURCE: Flasher Relay location- 1998 Mazda B3000 pickup 4x4
it's basically a stand alone relay... most times... look for a relay by itself and often round. my ford winstars flasher relay was actually located in the fuse box under the drivers side dash. it was blue and larger then the other relays so that may be a clue to you.
Robert
Please take a moment to rate this solution
Anonymous
  • 5 Answers
  • Posted on Mar 29, 2009
SOURCE: No turn signals or emergency blinkers
I had the same problem twice before. Solved it the same way both times. In my case it was the Hazard switch at the top of the steering column. It was stuck. I knew it was that because the signal lights had been functioning perfectly until I parked my car alongside the road with the hazard lights on to do some nighttime fishing and sip a little white lightnin'. (just kiddin' about the white lightnin')
When I got back in my car to go, I turned off the hazard lights but I had no turn signal lights! So I kept pushing that hazard button up and down for about 30 times with my left turn signal arm down until it started working again. So after having this happen to me twice, I learned a valuable lesson: Don't ever use hazard signals in this car.
ZJLimited
ZJ Limited
  • 17989 Answers
  • Posted on Nov 09, 2009
SOURCE: where is the flasher relay located for 1998 Toyota 4- Runner
Toyota Pick-ups, Land Cruiser, and 4 Runner 1997-00
Flashers -REPLACEMENT
The turn signal flasher is usually located in the convenience center, under the dash, on the left side kick panel. In all cases, replacement is made by unplugging the old unit and plugging in a new one.
Hope helped with this (remember rated this help) Good luck.
Anonymous
  • Posted on Jun 19, 2010
SOURCE: Where is the flasher relay located on
Where is a flasher relay fitted on a 1999 Mondeo 2l ?
ZJLimited
ZJ Limited
  • 17989 Answers
  • Posted on Jan 26, 2011
SOURCE: my turn signals and emergency flashers work some
For 1998 Ford Truck Explorer 4WD 4.0L EFI SOHC 6cyl the Flasher is located in front seating area, driver side, behind dash, mounted on steering column.
Both the turn signal flasher and the hazard warning flasher are mounted on the fuse panel on the truck. To gain access to the fuse panel, remove the cover from the lower edge of the instrument panel below the steering column. First remove the two fasteners from the lower edge of the cover. Then pull the cover downward until the spring clips disengage from the instrument panel.
The turn signal flasher unit is mounted on the front of the fuse panel, and the hazard warning flasher is mounted on the rear of the fuse panel.
Hope helps.
2answers
Turn signal flasher relay location on 2009 Nissan rogue
Please open the front hood and check for the relay by the headlights. It's good to have the product image with you so that you can use it as a reference to easily identify the relay once you come across it. Using any relevant diagrams in the car's documentation would also be helpful in identifying the relay.
Thank you.
I have a 2013 Nissan Rogue.Where is the block heater located?
A block heater is an aftermarket accessory that must be installed on your vehicle. A 2013 Nissan Rogue would not come standard with one.
Locate and replace the turn signal flasher relay in my 2012 Nissan Rogue....Fix rapid flashing for right turn
Rapid flashing on one side indicates a burned out bulb on the side that flashes rapidly. Check for a bad bulb.
Where is the turn signal flasher on a 2013 Nisson Rogue located?
You should check out www.reliable-store.com they have info on repair, service, wiring diagram, electrical diagram,
fuse diagram, troubleshooting, PCV, owner's/service/repair/parts manual, fault codes, error codes, etc everything on all vehicles. must check it out
2013 nissan rogue i/ok light what does that mean
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Nissan Rogue 2013 Factory Service Shop repair manual Year Specific FSM
Where is the windshield washer motor fuse located ?
images for 2009 Nissan Rogue SL Where is the
Windshield Wiper Pump - Not working - Nissan Forum ' Nissan Forums
forums.nicoclub.com/windshield-wiper-pump-not-working-t581434.html
Oct 22, 2013 - Year of vehicle -- 2011 Nissan Rogue SL Leather/Nav Package ... rather an engineer and found that my windshield washer pump was not ... sprocket: Posts: 150: Joined: Thu Jun 11, 2009 1:27 pm: Location: Metro Detroit, MI ... windshield washer fluid switch backwards ?
Apr 27, 2012
Windshield WASHFLUID ISSUE!
Dec 11, 2009
Front windshield sprayers not working..AHH!!!
Nov 10, 2009
More results from forums.nicoclub.com
Where is flasher relay located?
Most of the newer relays are built into the emergency flasher button assembly. Check to see if the emergency flashers work. But, some are are located close to the kick panel on driver side. It will be a full fuse panel with a lot of relays and minimal fuses. I dont know exact location because I have worked on so many different vehicles.
Turn signal flasher location
located under dash to left of the steering colume. note there are 2 flasher relays one for the emergency flashers and the other is the signal flasher. to know which one is the signal one turn on the emergency lights and look for the flasher the one that is clicking is the e-flasher. the signal flasher looks the same locate it and replace.
Top Nissan Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Nissan Expert? Answer questions, earn points and help others
