i-mate Jama 101 Smartphone Logo
How do I change my password for Apple I do - i-mate Jama 101 Smartphone
How do i create a new password for apple iphone
Follow these steps to change your Apple ID password.
Your Apple ID is the account you use to access Apple services like the App Store, Apple Music, iCloud, iMessage, FaceTime and more.
If you want to change your password If you know your Apple ID password and want to change it, follow these steps.
On your iPhone, iPad, or iPod touch with iOS 10.3 or later
  1. Tap Settings > [your name] > Password & Security.
  2. Tap Change Password.
  3. Enter your current password or device passcode, then enter a new password and confirm the new password.
  4. Tap Change or Change Password.
  5. Sign in with your new Apple ID password to access Apple features and services.
Learn more about how to change your Apple ID and update other account information.
On your Mac
  1. Sign in to your Apple ID account page.
  2. In the Security section, click Change Password.
  3. Enter your current password, then enter a new password and confirm the new password.
  4. Click Change Password.
2answers
I need to change the password on my apple ID
If you have access to your apple ID.
Open settings and select change password option.
Enter your current password and in next tab to it enter new password.
Press update password button below to it.
Forgot password. How can I reset my Apple account?
From Apple:
If you forgot your Apple ID password If you're having issues signing in with your Apple ID password, use these steps to reset it and regain access to your account.
Your Apple ID is the account you use for everything you do with Apple, like shopping the iTunes Store, signing in to iCloud, buying an app, and more. To reset your password, you'll need to know the email address for your Apple ID. If you're not sure which email address it is, there are a few ways you can find your Apple ID.
Reset your password
After you reset your password
Get more help Reset your password You can reset your password when you go to your Apple ID account page and click Forgot Apple ID or password. Enter your Apple ID, then click Next.
After you enter your Apple ID, there are a few ways you can change your password:
Answer your security questions
If you know the answers to your security questions, select "Answer security questions" and follow the steps to reset your password.
Use email authentication
If you select "Get an email," we'll send an email to your primary or rescue email address that you can use to reset your password. Didn't get the email?
If you use two-step verification
If you set up two-step verification, you can use it to change your password. You just need a recovery key and a trusted device. Follow these steps:
  1. Enter your Recovery Key.
  1. Choose a trusted device. We'll send your device a verification code.
  2. Enter the verification code.
  3. Set a new password and select Reset Password.
If you permanently lost your recovery key or access to your trusted device, you can't change your password.
If you use two-factor authentication
If you have two-factor authentication, you can reset or change your password from your trusted iPhone, iPad, or iPod touch when you follow these steps:
  1. Go to Settings > iCloud.
  2. Tap your name.
  3. Tap Password & Security.
  4. Tap Change Password.
  5. Enter a new password.
These steps will work only from a trusted device with a device passcode enabled. If you don't have access to a trusted device, you can reset your password when you follow these steps:
  1. Go to iforgot.apple.com and enter your Apple ID.
  2. Enter your trusted phone number and click Continue.
  3. Enter the verification code that we send to your trusted phone number.
  4. Provide any additional account information requested.
  5. Choose your new password.
If you can't sign in, reset your password, or receive verification codes, you can request account recovery to regain access to your account. Account recovery will take a few days, depending on what account information you can give. After you reset your password After you reset your password, you'll be prompted to sign in again with your new password. You also might need to update your password in Apple services and on your devices. Get more help If you're still having issues signing in with your Apple ID and password, make sure that you're entering the correct Apple ID. In most cases, your Apple ID is also the primary email address of your Apple ID account. If these steps didn't help you change your password, contact Apple Support.Last Modified: Feb 19, 2016
Login to my apple icloud
Reset your Apple ID password at https://iforgot.apple.com/password/verify/appleid .
If you use the same Apple ID for iCloud as you do for other Apple Services then changing your iCloud account password also changes your password for the other Apple services. If need more help follow Mac Support .
Apple id password reset
ollow these steps to change your Apple ID password. If you can't remember your password, follow the steps for what to do if you forget your Apple ID password.
  1. Go to My Apple ID (appleid.apple.com).
  2. Click Manage your Apple ID and sign in.
  3. If you have two-step verification turned on, you will be asked to send a verification code to the trusted device associated with your Apple ID. If you are unable to receive messages at your trusted device, follow the guidelines for what to do if you can't sign in with two-step verification.
  4. Click "Password and Security".
  5. In the "Choose a new password" section, click Change Password.
  6. Enter your old password, then enter a new password and confirm the new password. Click Save when done.
The next time you use an Apple feature or service that uses Apple ID, you will be asked to sign in with your new Apple ID password.
1helpful
Lost old apple password I PAD1
If you can't remember your Apple ID Password, or want to change it, use the password retrieval process at My Apple ID. Follow these steps to change your Apple ID Password:
1) Go to My Apple ID and click Reset your password.
2) On the next page, enter your Apple ID Name and click Next.
3) Authenticate by email or by answering the security question.
4) By following the emailed link or answering the security question, you'll be presented the option to reset your Apple ID password.
Top i-mate Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you an i-mate Cell Phone Expert? Answer questions, earn points and help others
