Open the expansion filler cap when engine cold, set temperature for heating to hot! Start engine and let the car run until operating temperature reached and watch water in expansion bottle for air bubbles being expelled!
Testimonial: "thank you for your advice, we will give it a try, see how we go, thanks"
Open the expansion filler cap when engine cold, set temperature for heating to hot! Start engine and let the car run until operating temperature reached and watch water in expansion bottle for air bubbles being expelled! When happy all air expelled close filler cap and then turn off engine!
No problem! Why do you need to bleed the cooling system?
Get the
coolant pressure tested, its definitely leaking coolant. You will need to get
the coolant running line.
Pressure
test will help you to know from where exactly coolant/refrigerant is getting
leaked.
For complete
step by step troubleshooting i suggest you to go through the help links
mentioned below :----
Click the
link below :-----
Coolant enters in transmission on Toyota Land cruiser?
http://schematicsdiagram.blogspot.com/2012/01/coolant-enters-in-transmission-on.html
1991 Toyota
Camry: Order Coolant Bypass Tube?
http://whatisbyme.blogspot.in/2012/05/1991-toyota-camry-order-coolant-bypass.html
2002 Toyota
Camry: Puff of Blue or White Smoke while Starting?
http://whatisbyme.blogspot.in/2012/05/2002-toyota-camry-puff-of-blue-or-white.html
1994 Toyota
Camry: Coolant Leak?
http://technoanswers.blogspot.in/2012/04/1994-toyota-camry-coolant-leak.html
2006 Cadillac DTS: COOLANT LEAK AT DRIVER SIDE NEAR
FIREWALL?
http://schematicsdiagram.blogspot.in/2012/04/2006-cadillac-dts-coolant-leak-at.html
MAF, IAT, MAP and Coolant Level Sensor problem all together
on Mazda MPV?
http://schematicsdiagram.blogspot.com/2011/12/maf-iat-map-and-coolant-level-sensor.html
GMC Engine Coolant Temperature (ECT) Sensor Replacing?
http://schematicsdiagram.blogspot.com/2011/12/gmc-engine-coolant-temperature-ect.html
Loosing Coolant?
http://whoisbyme.blogspot.in/2012/06/loosing-coolant.html
Coolant temperature sensor dies again and again?
http://schematicsdiagram.blogspot.com/2012/01/coolant-temperature-sensor-dies-again.html
2000 Daewoo Lanos: Where to Add Coolant?
http://repairhelpcenter.blogspot.in/2012/06/2000-daewoo-lanos-where-to-add-coolant.html
Blue Water Warning Light on Dash?
http://whatisbyme.blogspot.in/2012/07/blue-water-warning-light-on-dash.html
Replacing
Oldsmobile Engine coolant sensor?
How
to test Engine coolant temperature sensor?
Replace
Coolant Sensor Module on Oldsmobile?
These details will help.
Thanks.
Get the
Pressure
leaked.
For complete
Click the
link below :-----
1991 Toyota
2002 Toyota
1994 Toyota
FIREWALL?
on Mazda MPV?
Loosing Coolant?
Replacing
How
Replace
Thanks.
Land cruiser?
Replacing Oldsmobile Engine coolant sensor?
How to test Engine coolant temperature sensor?
Replace Coolant Sensor Module on Oldsmobile?
Thanks.
