Borrowed the machine from a friend she had it stored outside for how long I do not know.
SOURCE: I have a Necchi Royal Series 3205FA. I wanted to
If you have a stop motion dial with little grooves all the way round the best way is to get a wide plade screwdriver, put the plade part on one of the grooves on the left hand side of the dial and give it a thump on top with your hand, that usually does the trick.
SOURCE: the needle jams when i start sewing
Could be threaded wrong - check manual for proper threading
Needle could be bent - check and replace if needed
Needle plate could be damaged - see if any burrs are on it if so take to service dealer and have removed
Bobbin could be wound wrong - check manual
Bobbin could be bent - if so replace.
SOURCE: My Nechhi Royal Series Sewing Machine Has stopped working
this site is useless! I ask about a sewing machine and coffee makers come up wtfo?
