Question about Toshiba Satellite L305-S5939 (PSLB8U-0JC045) PC Notebook
My laptop does'nt work in normal mode but its working on safemode.thus anybody can help me how to enable a sound on safemode? thanks in advance for those who have idea
  • Toshiba Master
  • 2,942 Answers
"Safe mode" is really a diagnostic mode. "doesn't work" means what? Depending on what the problem is, we may be able to fix it. Please describe exactly what you mean by "doesn't work". Screen blank? Keyboard not responsive?
You can try setting the screen resolution to 640 by 480 while in safe mode, and see if that gets you someplace when you go into normal mode.
Posted on Oct 13, 2014
4 Suggested Answers
SOURCE:
  • 270 Answers
SOURCE: laptop starting in safemode.
after bios scrren press f8 then u can see windows booting menu select boot windows normally
Posted on Dec 22, 2007
Geekman
  • 32281 Answers
SOURCE: hey, i have my P2O5 toshiba laptop, it work in the safe mode, but on normal mode it don't work unless i disable the VGA from the safe mode, plz help
Try installing the latest video driver when you are in Safe Mode.
You can download thevideo and device drivers for your model laptop from the Toshiba WEB site from theirdownload page. Make sure you enter the model of your laptop so you can get thecorrect drivers. Please click on this link: - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
Posted on Apr 20, 2012
Geekman
  • 32281 Answers
SOURCE: \windows\system32\config\system 0xc00000e9 toshiba vista
Restore Toshiba to Out of the Box Condition
If your model Toshiba laptop has a Restore partition on the hard drive then follow these steps to restore your Toshiba to the Out of the Box condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power button once to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the system recovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
Posted on Oct 05, 2012
Windows won't start with safe mode
Download a new safemode for dell. my safemode wouldn't work too.
Apr 13, 2013 | Dell Latitude D520 Battery PC Notebook
Hi I have a fujitsu amilo pi 1536 laptop and wish to return it back to factory settings. All i have is the laptop and no recovery disks etc. I've tried pressing F8 which brings up the windows advanced...
OK
You have Vista
EASY
In CONTROL PANEL select RECOVERY
Then "Advanced Recovery Settings"
Then "Return your computer to factory settings".
Be AWARE you will loose all of your files and after market downloads.
May want to BACK-UP!
Aug 02, 2011 | Fujitsu AMILO PC Laptops
My laptop Acer 5315 start up led comes on and then shuts down almost immediately. Could this be hard disk failure?
Definitely not. If you are experiencing a Hard Disk failure, you will experience a very slow computer. Sometimes you will also hear crackling sound on your laptop. Automatic shutdown can be attributed to either processor of video card failure. Try to start your computer in safe mode or enable VGA mode. Tap on F8 on restart then choose either of the options once you get the Advanced Boot Options. If it worked, then there are another two possibilities.
1. Video card driver is corrupted. Try to reinstall the video card driver 2. Video card is defective. Bring it to the service center.
If the safemode or enable VGA mode does not work, you have a big problem cause you need to replace the Processor of your system. It is one of the most expensive components of your computer.
Jul 01, 2011 | Acer Aspire 5315 Notebook
My advent notebook 4211-B won't start up, it turns
Hi
Its mean you windows is corrupt may be due to virus infection or some body delete the system file. ok don't worry please take the windows Installation CD and repair your windows, don't worries about your data it will safe, for repairing the windows guide book is available hear.
Select your operating system
Windows 7
WIndows XP
If my solution fix your problem give me the thumb
Jun 23, 2011 | Microsoft Computers & Internet
Well im in safe mode on my computer, will my webcam work?
When in safemode only the needed Windows drivers are loaded, thus your webcam will not work in safe mode.
Oct 12, 2010 | Computers & Internet
Unable to paly sound in safemode.
HI,
You would not be able to play any sound in safe mode. As including the sound card , no other drivers get loaded. Drivers are peice of software that gets installed on windows to make your audio work. Safe mode is a diagnostic mode, so none of the drivers load in safe mode. Would request you to restart the computer in normal mode and then check for the sound
Thanks
Proton
Sep 03, 2010 | Toshiba Satelite 2405-S201 Notebook
MY Dell laptop running XP will run in safe mode but shut down after 2 minutes in normal operation. When I start it defaults to safe mode but allows me to restart and comes up temporairialy in normal mode...
Hi Friend, If your system only boot up in safemode, you should try a Clean Boot of your machine to help given steps, 1- click Start, and click Run. The Run window appears(From the safemode desktop) 2-. In the Open box, type msconfig and then click OK. The System Configuration Utility appears. 3- go to the General tab and click Selective Startup radio button. 4- Un-check all options with the exception of "Load System Services" & "Use Original BOOT.INI". 5- Click Apply, and then click Close. 6- When prompted to restart the computer, click Yes. Now if it boot up in normal mode you should get a message to the effect of the changes you just made in msconfig, don't worry about it, but make sure you put a check in the box that says "Do not show me this message again" and click the "OK" button.
Thanks,
Jan 01, 2010 | Toshiba Satellite A100-S8111TD Notebook
Compaq pesario C300 not starting
Have you tested your harddrive to make sure it's working properly,or you are maybe missing ntldr
Dec 10, 2008 | Compaq Pesario S4120WM (DK216AR#ABA) PC...
Toshiba Satellite L305-S5939 (PSLB8U-0JC045) PC Notebook Logo
35 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
