SOURCE: paslode angle finish nailer the fan wont run
have had the same problem! started with a noisy fan then a non responsive one. try taking out the fan assembly as per service and drop a couple of paslode lube drops along fan shaft and gently compress fan to lubricate bearing, may not be a lond term fix but hasnt stopped since and that was over 2000 2inch ago. good luck.
SOURCE: Paslode finishing nail gun won't fire? Battery is
Give it a thorough cleaning.. if it still does not fire you might have to replace the spark plug.
SOURCE: Paslode impulse finishing gun wont
Hi, heatman101
Here is a tip that I wrote
about the Paslode nailers and the problems that can come up
with them.
I also have a link to the Paslode manuals
which contain Paslode cleaning and troubleshooting guides.
If
you need parts for your Paslode, there also is a link for a
site that sells the Paslode nailer parts.
Paslode
Cordless Nailer Problems
SOURCE: Paslode Impulse Framing Nailer won't operate
Hi, heatman101
with them.
If
Paslode
Sounds like a battery contact problem or a bad battery..
with them.
If
Paslode
heatman101
with them.
If
Paslode
heatman101
with them.
If
Paslode
heatman101
with them.
If
Paslode
heatman101
with them.
If
Paslode
heatman101
with them.
If
Paslode
heatman101
