Fn/F2 probably turns the wifi on/off but your problem is you need to connect to the new device, and enter the new password. In the tray (notification) area, click the Network or wifi icon, find the new device (You may have to click Connect first.), connect to it and enter the password when prompted.
To turn on wifi connect the power cord from your routers to the power outlet box then connect a computer to one of the rg45 or LAN of your router check the manual of your router for setting by using your browser with the ip specify on your router's manual eje: http:\\192.196.0.1:80 on your browser it dependent the manufacture of your router. And locate it the right setting or power ciacle the router by turning it off or desconnecting from the out let for 5 minute and make sure your computers have wireless on look by the button sing of wireles on your computer hold it and let go until you see the wireless light
Deepa christopher Unfortunately, you cannot make the computer a hotspot without a wireless card installed. You could add a wireless card and then search the internet on how to setup the computer as a hotspot with the OS installed on the computer. Thank You, Dell-Jesse L Dell Social Media and Communities
The easiest method of connecting any computers is to use a router which will also provide a DHCP server component to serve up local TCPIP addresses to each connected computer.
To connect to the router you would need standard ethernet cables which are available widely and which would plug into the network port of the computer and the other end into the port on the router. You need one cable for each computer to router connection.
If you have computers with WiFi / wireless capability, then you would need a wireless router and could then connect without the need for cables.
Take a look at the Practically Networked web site which has revies of various types of routers and also provides tutorials on networking and other related subjects which would help you.
yes but you will need to download a wifi driver in the Dell so that it can communicate with the wifi service provider
best download the driver from the modem used for the connection
There is a reset switch on the router you have at home. Use a paper clip to press and hold the reset button in for a few seconds to allow the router to reset. This will reset the router to default settings and you should be able to connect to it at this point. Log into the router and set up a securty key so that no one else cans steal your internet
