Sewing Machines Logo
A
Anonymous Posted on Oct 12, 2014
Machine won't stitch
The machine will not stitch at all have checked bobbin, threading tensions needle
Linda M
Level 1:
New Friend:
  • Contributor 15 Answers
  • Posted on Oct 14, 2014
Linda M
Contributor
Level 1:
New Friend:
Answers
15
Questions
Helped
3139
Points
34
If by "won't stitch" you mean that the top thread will not pick up the bottom thread, make sure you have the needle threaded properly. If the machine is a top loading bobbin, the thread goes in the needle from front to back. Same if it's a side loading bobbin (bobbin faces you as you sew). If it's a front loading bobbin (bobbin faces left of machine), the thread goes in the needle from left to right.
5 Related Answers
Anonymous
  • 3 Answers
  • Posted on May 22, 2008
SOURCE: Bernina Bernette 600 Deco embroidery machine
It could be that there is a loose piece of thread, or some fluff which is obstructing the tension gauge. Try blowing around the theading area (or even run the hoover pipe near it to see if you can **** it out). I cleared mine by folding a piece of non fluffy material and rubbing gently between the tension dial and machine.
Good luck
Anonymous
  • 323 Answers
  • Posted on Jun 27, 2008
SOURCE: Loose stitching underneath. HOW CAN I FIX!!!!
Sounds as though you may have a burr or rough spot on the hook where the bobbin inserts. Run your finger along the edge of the hook to see if there are any rough spots.I'm sure you're going to find at least one from the time you broke the needle.Once you locate it, remove it with an emery stick or small sharpening stone. Polish it so that it is smooth. Should work okay.
sewman7
Anonymous
  • 6 Answers
  • Posted on Feb 21, 2009
SOURCE: Singer CG 550 Top thread keeps wraping around the bobbin and jam
Have you checked the top thread is correctly placed in the spring of the bobbin case?
Anonymous
  • Posted on Mar 15, 2009
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Anonymous
  • Posted on Apr 04, 2009
SOURCE: janome straight stitch loose
I don't know if this is the right answer for any of you, but thought I'd put my 2 cents worth in. Often this can be the bobbin in backwards. It needs to unwind a certain way depending on the machine. I've heard a phrase for this: Mind your p's and q's which means some wind off to the right like a q, others to the left like a p. Mine has to unwind one way then be slipped backwards into a little slot or it does that loose bottom thread looping and bunching someone here mentioned. It seems everytime I get that problem I rethread the top thread 100 times before it clicks again and I remember it could be the bobbin thread. Either your manual will tell you the correct way, or you could experiment and try one or the other. Once you figure out whether you're a p or a q, mark it on your machien somewhere to remind yourself.
Good Luck and Happy Sewing!
I have a babylock emp6 and it starts stitching the design then stops and says check upper or bobbin thread. THe threads seem fine it stitches a bit then says the same thing what can the problem be?
If your Babylock EMP6 embroidery machine starts stitching a design and then stops, displaying a message to check the upper or bobbin thread, there are a few potential causes for this issue:
  1. Thread tension: Improper thread tension can cause stitching issues. Ensure that both the upper and bobbin threads are properly threaded and the tension settings are adjusted correctly. Check the machine's manual for specific instructions on setting the thread tension.
  2. Thread breakage: Check both the upper and bobbin threads for any signs of breakage or tangles. A broken or tangled thread can cause the machine to stop and display the error message. If you find any issues, rethread the machine and ensure the threads are properly seated in the tension discs and bobbin case.
  3. Bobbin issues: Check the bobbin area for any obstructions, such as lint or tangled thread. Clean the bobbin case and ensure the bobbin is correctly inserted and spinning freely. If the bobbin is wound unevenly or has any defects, replace it with a new one.
  4. Needle issues: A bent or dull needle can cause stitching problems. Check the needle for any damage and replace it if necessary. Make sure you are using the correct needle size and type for the fabric and design you are stitching.
  5. Machine maintenance: Regular cleaning and maintenance are important for the smooth operation of the machine. Clean out any lint or debris from the bobbin area, needle plate, and thread path. Lubricate the machine as recommended in the manual.
12 wt thread
12 wt thread generally will not work well in the bobbin...
"Aurifil 12wt Thread
Aurifil 12 wt thread is ideal for hand quilting, big stitch hand quilting and machine quilting. 12 weight thread creates a more defined and often primitive look. It's great for designs that use a longer stitch length if using a machine. When machine quilting with 12 wt thread, use 40 wt in the bobbin, increase your stitch length, lower your tension, use Topstitch size 90 needles and stitch slowly."
2answers
Bernina activa 210 won't zigzag and has bobbin issues on straight stitch
it's very possible that the machine is slightly out of time & needs to be service at a sewing machine shop
is the fabric & thread & needle compatable with each other?
did you use every thread guide when threading the machine?
is the bobbin in correctly?
is the bobbin warped?
6helpful
Stitch tension problem - bobbin thread lies flat or bunches. If you increase the needle thread tension there is no improvement - even at the highest needle thread tension the bobbin thread is a mess. Any...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Needle keeps jamming, won't thread
Good day!
Good day!
I am experiencing tension issues. Same fabric and thread, worked with the first spooling of the bobbin. Re-spooled the bobbin and now the tension is all messed up. Cannot tighten, and it's gathering...
Good day!
Good day!
1helpful
Necchi 535FA--the tension seems to be off. The thread keeps breaking or pulling out of the needle. When i sew on cotton it was working then when I switched to a stretchy faux crushed velvet the tread...
Good day!
Good day!
1helpful
My singer curvy 8780 has a timing issue the needle is scraping on the bobbin casement and will not sew,cleaned and oiled, changed needle turned off and on. any suggestions?
Good day!
Good day!
2helpful
Keeps skipping stitches and knots thread
Good day!
Good day!
3helpful
Cannot get the tension right and the thread keeps braking
Good day!
Good day!
Top Sewing Machines Experts
SmartAviator
SmartAviator
Are you a Sewing Machine Expert? Answer questions, earn points and help others
