SOURCE: about the normal temperature of dell mini inspiron 10
you can use a external fan designed for notebooks, there a syte,
http://www.dmail.pt/prodotto.php?cod=180634-107&np=1
SOURCE: loud beeps at start up dell inspiron mini
Beep codes for the Inspiron Mini are as follows:
Beep Code Possible Problem
One Possible system board failure — BIOS ROM checksum failure
Two No RAM detected
NOTE: If you installed or replaced the memory module, ensure that the memory module is seated properly.
Three Possible system board failure — Chipset error
Four RAM read/write failure
Five Real Time Clock failure
Six Video card or chip failure
Seven Processor failure
Eight Display failure
SOURCE: fomating dell inspiron mini 10
Resetting
a Dell Inspiron mini 10 to the factory settings allows the user to restore the
Dell Inspiron to the original operating condition as if it was just
taken out of the box. Dell system includes a restore utility called 'Dell Symantec System Restore' to reset or restore your Dell system to factory setting.
Step 1:
Before reset any Dell Inspiron mini 10, backup your all important data
and programs, otherwise you may lose it. It is recommended to use an
external storage device for your entire data backup, so that you couldn't lose it in any sudden occurring issue...
Step 2: Remove any other unnecessary external drive and restart your Dell Inspiron mini 10 laptop.
Step 3: Press 'F8' key continue until 'Advanced Boot Options' wouldn't be appear.
Step 4: Use your keyboard arrow key to select 'Repair Your Computer' from the list and hit 'Enter'.
Step 5: Now click 'Next' and login as the administrator account.
Step 6: Click 'Dell Factory Image Recovery and Data Safe options', select your language option and click 'Next'.
Step 7: Click the check box 'Yes, reformat hard drive and restore system software to factory condition' and click 'Next' to start Dell Inspiron mini 10 reset process...
This
process will erase all your previous changes that have been made to the
Dell Inspiron mini 10 and reset the configuration settings to factory
setting.
Feel free to get technical assistance for all type of Dell mini 10 at http://www.vtechsquad.com/dell-support/
SOURCE: How do I reset my
There are some other way to reset Windows password with a bootable CD/DVD or USB flash drive. It is not so troublesome that you forgot Windows password, you can see this article about Windows 7/Vista/XP/2008/2003/2000 password recovery. Two steps:
Reset windows password with "Advanced WIndows password recovery tool"
These tools is to reset the password offline.
1. Create a password reset disk;
2. Reset Windows 7/Vista/XP/2008/2003/2000 administator password offline!
