The item sent has too large a hole and is not flat.
SOURCE: Please advise on where to puchase replacement
Hi howardandjan, You call it "old Qualcast punch" if it's called Qualcast punch it's not that old, it was originally called Suffolk punch (after the horse) and came in 14" and 17" cuts, the 30s (30cm approx 12") was originally called suffolk colt. when Qualcast took over just about all the british cylinder mowers Atco,suffolk,webb etc they started swapping names about but you should be able to get parts from any good mower shop try winchester garden machinery in hampshire always found them helpful
SOURCE: Seized motor bearing causing fan and housing to melt
How old is your mower? Qualcast claims a 5 year guarantee on the Power-Trak 34. Either way, here is a parts list for you: http://www.powertoolspares.com/qualcast-garden-spare-parts-4/6000554/qualcast-rotary-mowers/2002164/lawnmower-power-trak-34-spares/F016508042/F016508042.php
SOURCE: Guide pins for mower blade believed to be sheared.
Just enough to guide the blade in place so the screw can be tightened to secure the blade. BUT - you might have sheared the flywheel key that times the flywheel and ignition system.
SOURCE: how do you change a blade on a qualcast lawn mower
Block the blade with a piece of wood so it stops the motor and blade from turning while your loosening the nut.
SOURCE: Qualcast Motor Mower Starts but will not run
there will be a butter fly in the carb that pulsates this is conected to rev cable plastic may have snapped or cable come loose
take it it is petrol
INCORRECT PRODUCT CATEGORY
I'm sorry but I believe you have this posted in the wrong product category. Please re-post the question in the proper category This is the car and truck problem category
