unpair jbl speaker in windows 10
then put jbl speaker into pairing mode
then on windows 10 pair speaker in bluetooth settings
then
test speaker to see / hear if it now works
so what makes you think the laptop has BT? its and option on all PC made, when new (check this first)
is this the only BT device you own? do tell. and can be added to any PC on earth with a BT USB dongle stick. for like $4 what is the distance to the speakers (BT uses radio signals weak) 10ft 50 ft (10 meters) what? distance matters on all transmitters regardless if BT, wifi, wlan, or 3g/4g/. etc...
BT comes in 2 power settings, some devices do not use high power mode. (on speakers this would make for best) does the speakers pair with any other PC? with BT?
the speakers if not junk has RTM manual. and read the page on how to reset pairing. BT loves to memorize your favorite devices, so if problems happen. learn how to reset that memory , call reset pairing history.
You may try turning off the bluetooth on your phone, turning off the speaker, turning back ON the speaker and then turning on the bluetooth on your phone again. This should reset the phone to SEARCH for BT-100.
Once you SEARCH for available devices you should see BT-100 on the list. Select BT-100 and it should pair. If it does not CONNECT be sure to press BT-100 again to connect. The speaker will BEEP, indicating that the speaker and the phone are now connected.
If you continue to have trouble feel free to contact the manufacturer at [email protected] or going to http://www.contelusa.net
You will need to be sure that your device has BLUETOOTH. If it has bluetooth please turn on the bluetooth settings on your android device. You will now want to turn on the speaker.
Using the android device you will search for available bluetooth devices. Once you see BT-100 you will select that to PAIR. Some devices will automatically CONNECT after the devices have been paired. If not, please press BT-100 again to CONNECT. The BT-100 speaker should BEEP indicating that they have connected and the speaker is now ready to use.
The speaker can only pair with one device. I had the same issue pairing it with my phone and then to my iPad.
You simply need to unpair it with your daughters iPod by turning off the bluetooth on that iPod, turn off then back ON the speaker and connect again to your own iPod by turning on the Bluetooth, Selecting BT100 from the list and wait for it to say CONNECTED (not paired). Hope this helps!
Go to settings, General, blue tooth and remove any "other" previous paired BT devices & Turn off BT, then go to Sett. General, scroll down to reset and reset network settings, this will not delete anything. Power off BT speaker. after iPad re-boots turn on BT Speaker First, make sure BT is off on iPad as well as WIFI-wait like 10-15 seconds and then turn BT on in iPad it should see your speaker now and let you pair it up.
Here is a solution that might work on your HTC Thundermug. The User's Guide indicates "activate bluetooth pairing mode by pressing the Power button". It should indicate to press and hold the power button. Pressing and holding resulted in the headset being recognized within 5 seconds by the HTC Thunderbolt. This is a problem with the User's Guide. How to Pair the Plantronics 510 Headset Good Luck from Headsets Direct!
I have an HTC Desire, I find that if I answer on the phone by touching the phone screen's answer button it answers in the phone :( But if I push the button on the bluetooth to answer it answers in the bluetooth - very annoying but appears to be an HTC issue not motorola's
