MAXIMUM LOAD WARNING
45 and 50 CALIBER RIFLE:
45 Caliber Pellets come in one size: 50 grain
50 Caliber Pellets come in two (2) sizes:
50 grain volume equivalent which equals 50 grains of loose powder by volume.
30 grain volume equivalent which equals 30 grains of loose powder by volume.
The maximum load per shot should never exceed total Pellets containing more than 100 grains volume equivalent. That means, no more than:
45 Caliber 1) Two (2) 50 grain Pellets
2) Three (3) 44/45 caliber 30 grain
50 Caliber 1) Three (3) 30 grain Pellets, or
2) Two (2) 50 grain Pellets, or
3) One (1) 50 grain Pellet and one (1) 30 grain Pellet
54 CALIBER RIFLE:
54 Caliber Pyrodex Pellets come in one size only:
60 grain volume equivalent which equals 60 grains of loose powder by volume.
The maximum load per shot should never exceed 120 grains (2) Pellets.
SOURCE: Simmons Prohunter Model 517710 won't shoot a group
You SHOULD send it back. There is something loose inside the scope. Even the worst Simmons scope will get you to 2"-3" group. Also, when you replace it, you might want to consider their (or Nikons) shotgun scopes. They are built to with stand the power of the higher centerfire calibers and magnum shotgun shells.
SOURCE: I am using Hodgdon 4895 smokeless powder and a 200
Oh me, that was fun I have not got out my books for so long. Ok this is from Hornady Handbook Starting load for the 200 gr RN Bullet using H4895 is 34.3 gr using a Remington case with a Federal 210 Primer Max C.O.L. (Cart.over all length) is 1.920. Max load for this is 39.0 gr. Work up, look for case bulging & primer flowing. Be carefull.
SOURCE: I need a manual for a euroarms model 1861
Ok, I do not know of a manual for your gun. The main thing is learning to handle, load and shoot a muzzle loading gun. Here is a link to You Tube to see others firing similar guns. >> Here 460 grain Lyman conical bullet would be about 30 grains of black powder or FFg in Pyrodex. See load chart >> here > here
SOURCE: Marksman 44-1c Cal 4.5 (.177) Spring loaded Pellet gun
All I can tell you is that Beeman is the maker, and Marksman is just a model.
