I need to connect a panasonic SB Wa 05 powered subwoofer speaker system to my amplifier. Do not see any input jacks, only a multipin cable. Where are the inputs?
Model SB wa 05
  • George Smith
    George Smith Sep 17, 2019
    I'm having the same issue. Any idea how I can solve it
    Top Expert:
  • Audio Player... Master
  • 54,195 Answers
The multipin cable takes the place of separate "jacks".
Posted on Oct 12, 2014
  • Bob Cantner
    Bob Cantner Oct 12, 2014
    Thanks but I don't have the cable or anything to p[lug it into.
5 Suggested Answers
SOURCE:
  • 104 Answers
SOURCE: need to connect panasonic sb wa730 to panasonic sa dp1 system
There is a subwoofer outlet at the back of the sa dp1 connect via cable to the inlet on your sub then on your sa dp1 remote press shif and subwoofer at the same time
Posted on May 23, 2009
jedweller
  • 21 Answers
SOURCE: Panasonic sb-wa 340 active subwoofer
This is normal operation.. The subwoofer will only play sounds below a set frequency...There may be a crossover setting in your menu that you can adjust the frequency cutoff to your liking.
Posted on Oct 01, 2010
  • 19 Answers
SOURCE: CAN I REPLACE MY 2.7 OHM SUBWOOFER WITH A 4 OHM SUBWOOFER ON MY S
No Harm will be done if you do this,compleatly 100 precent safe.
Posted on Oct 28, 2010
dunnbiker
  • 8546 Answers
SOURCE: I have panasonic active subwoofer
It's not clear if you have the SC-HT800, too, but the manual for the '800 includes the SB WA330.
http://service.us.panasonic.com/OPERMANPDF/SCHT790V.PDF
Thes Theater in a Bx systems are highly proprietary as evidenced by the unique interconnections. Mix n match is DIScouraged if not actually dangerous to the components.
Posted on Feb 19, 2011
What is code 05 on the intexsaltter system wa
Code 05 is 5hrs cycle time.. 00 to 12 are cycle hrs and should count down after system starts...
Jul 16, 2011 | Intex Automatic Salt Water System for ...
I have panasonic active subwoofer sb wa 330.i didnot get the manual.can u tell me where can i get instruction manual. manu manukt76@gmail.com
Feb 19, 2011 | Panasonic SC-HT800V System
Panasonic sb-wa 340 active subwoofer has just low freequensy noice from subwoofer ! The other speakers working good and dvd fanction normally !
Oct 01, 2010 | Panasonic SC-HT690 System
Receiver cannot recognize subwoofer
As I implied earlier, take a clue from the physical style of connectors for both parts of the subwoofer function in the old and new receivers:
RCA connections are for Line Level signal between components only.
The input (bare wire) at the speaker is for AMPLIFIED signal.
You can't just modify one to fit the other and expect magic to happen. Be glad you didn't do it the other way around and modify an amplified (speaker level) outout into a Line Level input. You likely would have smoked that component.
Your subwoofer is a passive speaker, that is, like any other speaker it needs an amplifier. Many subs are self-powered (amp built-in) and they would mate well with the RCA sub output of the receiver.
Get yourself an Active (self-amplified) Subwoofer and run UN-MODIFIED RCA cables to it, according to its instructions, from the Sub Out of the receiver. Or get an amplifier between your receiver and the sub you have.
Feb 21, 2010 | Pioneer VSX-D607S Receiver
Sync speend
1/125 of a second, according to Nikon, but I've found on my N8008 that using 1/60 is more reliable.
if you use one of Nikon's dedicated Speedlights (SB-24, SB-23, SB-22, SB-20, SB-18, and SB-16B) then they set the synch speed automatically.
Jul 01, 2009 | Nikon N6006 35mm SLR Camera
Simple question?? how do I connect my Panasonic subwoofer to my denon receiver?
I have a very similar problem with the same exact Panasonic sub. I went to Best Buy and Radio Shack looking for an adapter, and they basically told me that one does not exisit. Apparently, Panasonic designed the home theater system specifcally so that it could not work if any part of the entire system was ever seperated.
May 27, 2009 | Panasonic SC-HT930 System
Which jacks to wire the subwoofer to?
Your receiver should have an RCA connector on the back panel that will be marked "sub woofer" or "LFE out". That connects to your sub woofer with a standard RCA type cable. Also, some powered subs have left and right speaker level inputs and outputs in which you would indeed run the sub woofer through the speaker outputs. The down side of that type of connection is that the line level converter inside the sub woofer will take a slight amount of your receiver's output power, although that is rarely detectable. Also, if you have a Dolby Digital receiver, using this connection method will take away systems ability to accurately control the low frequency effects of a soundtrack.
Good Luck,
BB
May 16, 2009 | Kenwood Audio Players & Recorders
Sb-22 flash fires but d60 still opens the bilt in fash
I think you will need to upgrade to the 22s. It sounds like the newer model provides the D60 with a 'handshake' signal that the older 22 model does not have.
Sep 01, 2017 | Nikon Speedlight SB-22S TTL Flash
526 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
