How do I replace the front fork tubes on a Tao Tao 50cc scooter? Need a video show steps and procedures?
SOURCE: front fork oil capacity
Hi
You can download the whole workshop service manual that has this info and heaps more from here. Hope this helps Thanks for using Fixya.
regards
robotek
SOURCE: front fork oil seal replacement
General intructions for most bikes:
Remove front wheel. Loosen fork tube clamps at top and bottom of triple clamps. Slide fork tubes out and remove. Access to seals is from top of tube. Remove cover and unscrew cap. Shop manual for specific bike is $24-$30. Will show detailed instructions.
Good luck;
Techjoel
SOURCE: front fork leaking oil from bottom of the seal.
Before you take it to the shop try this.Get some camera film,Cut the notched edge of it and trim the top to an angle of 45 deg..Slide this up into the fork seal and working it up and down,slide it all the way around the seal.When you get the feel of it,you can feel tiny bits of grit.This will clean the grit out 99% of the time.I always keep a piece of film in the toolbox.
SOURCE: 2000 buell m2 cyclone leaking fork seals
Check out badweatherbikers.com and I am sure you will find everything you want about working on your Buell. Good luck
SOURCE: Yamaha xj 900 s Front fork oil amount in cm
The forks hold 286ml or 9.67 US OZ of oil, best would be to use hydraulic oil.
Good Luck.
