Here is the string: :If Z=Y <-- Pressing Goto at the error throws me here :Then :Disp Z :Else If this problem wasn't asinine enough, trying to type in Z=Y in the calculator after I run the buggy program also yields a data type error. After running the program that runs just fine, typing Z=Y yields no error.
SOURCE: T.I 84 Plus Calculator
Well, this might not be right, but check the Brightness. Hit 2nd, then the down arrow. repeat this a few times. see if that works.
SOURCE: Calculating out npv and irr
Use the "FINANCE" app:
[APPS] [1] [ENTER]
for npv: select "7:NPV"
now you should get "npv(" on your screen.
use: npv(interest rate, cost {cash flows}, {frequencies of cash flows})
for irr: select "8: irr"
"irr(" will come up.
use: irr(interest rate, cost {cash flows}, {frequencies of cash flows})
SOURCE: Error message on TI-83. What does it mean?
It means that you have put the wrong things together. E.X. String>Equ(x,y) when x dont equal a Yvar. and y dont equal a string number (StrZ, Z=#'s 0-9)
SOURCE: Unable to get any response other than syntax error
Push the button that says "2nd", then push the number "0". This will reset the calculator. After resetting, it should work again.
