Canon PowerShot A610 Digital Camera Logo
A
Anonymous Posted on Oct 12, 2014
Download cd rom powershot a610
Want to download cd-rom for camera Poweshot A610
Jay Plesset
Level 3:
  • Canon Master 2,942 Answers
  • Posted on Oct 12, 2014
Jay Plesset
Canon Master
Level 3:
Answers
2942
Questions
Helped
668549
Points
9879
5 Related Answers
Anonymous
  • Posted on Aug 03, 2008
SOURCE: Powershot A610 Problem
No luck so far. some idiot copied an pasted my posting as a solution. thats it so far. if ya figure it out let me know
Anonymous
  • Posted on Aug 13, 2008
SOURCE: Canon Powershot A610 won't power-up
My camera stopped working some time later after being dropped.
If you are brave (or desperate), try this... I found it was not too difficult to open the camera up. Take all the screws from the bottom, sides and under the card and usb, and inside the battery compartment. They are all different lengths so keep some record of what goes where. Then I made sure the multiway connector underneath the top was firmly in place. That was all I could see that I could fix myself. And what luck! when I put it back together it worked.
Anonymous
  • Posted on Nov 11, 2008
SOURCE: Replacing a part on my Canon PowerShot A610 Digital Camera
is it the same Powershot A540 as well?
t00nz
CameraR
  • 4738 Answers
  • Posted on Nov 15, 2009
SOURCE: My Canon powershot A610, will not be reconized by
This question comes up several times a day here in the camera section at Fixya. But please note, it's very hard to troubleshoot individual software problems online, and it likely is a software issue. But why put up with the headaches of bad software in the first place?
Please don't take the following as a sales pitch as it's not, but please see this article, as it describes the use of an inexpensive card reader as a much easier, faster, and less error prone way to download your photos. In fact there are several important reasons discussed in the article for using a card reader vice downloading from the camera. USB Card readers are also very inexpensive these day, with cost virtually not an issue.
leecom72
Lee Hodgson
  • 4810 Answers
  • Posted on Jul 16, 2010
SOURCE: how do I format the memory card on the Canon
The option to format the card should be in the camera's menu.
To do it properly consult the manual.
Other than that you can pop the card in a card reader, connect it to a computer and format the card that way.
Regards.
Canon power shot A610, will it support sundisk 16GB?
No. The A610 works with MMC and SD cards, 2GB or smaller. It will not work with higher-capacity SDHC cards.
2helpful
Memory card error with 4gb card
Your camera was made before 4GB SDHC card format came out. Sorry, but a Powershot A610 can only work with 2GB or less standard SD cards. Fortunately, these are very inexpensive these days. If your local store doesn't carry them, then here's some from Amazon.
2answers
Free download of Instruction manual for Canon Powershot A610 digital camera 2005
You can download and print the instruction manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps you. Thanks for using FixYa.
4helpful
My canon powershot a610 has a black screen
Try the solution posted by frozen80 at http://www.fixya.com/support/t295396-canon_s2_black_screen. It fixed my Canon PowerShot A610 black screen (closed diaphragm) problem.
2answers
Lost cd installer
it can be downloaded from here PowerShot A610
select yuor details.
riz.
3answers
you will need a #0 screwdriver. 1. remove the screws on the sides two on one side three under the Digital/dc in / av out 2. removed the screws from inside the battery compartment three total screws Cheers! PS these are small screws. Work in a well lit area!
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
