Trying to broadcast live. computer only recognizes camera when attached with usb and removing info from the camera. Can this camera be used to do a live broadcast?
Thank you! We have picasa3, but I can't figure out why the computer won't recognize the camera unless it is accessing the everio library. any ideas?Thank you! We have picasa3, but I can't figure out why the computer won't recognize the camera unless it is accessing the everio library. any ideas?
You can't post conmments that contain an email address.
This camera can be used for live broad casting in televisions by default. but if you need to live broad cast in computer then you have to install some softwares like picasa3 in your computer.
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Dear crane_editor,
For broadcasting the video signal coming from the V-8 over the internet you need to have a computer that is equipped with a composite or S-Video input card. Additionally you might need an audio input as well with the possibility to delay the audio to have a live stream with lipsync audio and video.
Roland has launched a new product recently which is actually designed for live streaming applicatons like this. It's called VR-5 AV Mixer & Recorder. This device has a USB streaming output for easy connecting with a computer. The computer will recognize the VR-5 as a USB audio/video class device (like a webcam) so your setup is ready in minutes.
Further the VR-5 is equipped with an audio mixer (with delay for lip sync), built-in preview screens with touch select, PC VGA input, media player and AV recorder (SD card).
Probably the VR-5 covers all of your needs, without the hassle of difficult configuration of all kinds of separate devices.
Kind regards,
Kees
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
I ended up solving this by briefly removing the memory card and the battery from the camera, then reinserting them. This seemed to re-set everything and it then all worked well!
It sounds like you don't have software on your PC that will recognize the camera when connected. I am going to recommend that you do not use the camera to upload photos. It is better practice to use external (SD) memory cards and remove them from the camera to upload. You can use a USB SD reader or purchase SD cards with a built-in USB interface. You should be able to see a new drive when connecting the SD card to your computer; then all you need to do is copy over the images. One advantage is that you will save camera battery while uploading because you dont need the camera at all. It also allows you to take images with you without taking the camera, i.e. school or work. I hope this helps...californiajones
Using the firewire/IEEE cord attach the camera to your computer. If you are using a Mac it should instantly recognize the external camera when you open iSight or what ever utility you are using to communicate. If you are using a Windows based computer open MS Moviemaker and it will recognize the camera as well by selecting capture -- once the camera is recognized you should be able to broadcast with it. If you are using uStream.com sometimes your video capture interferes with the ability to broadcast. In that case hook up the camera using firewire, connect to uStream -- grant uStream permission to capture using the camera then you can see the video in your browser window.
