After de scaling ,the two lights keep flashing, have tried holding down the large cup button for 5 to 10 seconds,still keeps flashing.
SOURCE: De Scaling instructions
Also, if you have an in sink garbage disposal, don't waste the hot vinegar. Pour it into the disposal, turning the unit on as you pour, off when you're done. The vinegar is mildly acidic and will disinfect the disposal unit.
SOURCE: lights keep flashing on my tassimo machine
if your lights are flashing on your mashine just keep your finger on the button untill its filter threw, willtake up to 2 mins. simon bernasconi
SOURCE: Hi, My Saeco Magic Deluxe has been in storage for
Your In your http://www.partsguru.com/user/MDL_5.pdf This propel The There is also
problem you describe is frequent when you leave the machine unused for long
time. The reason is due to the fact that the water that were in the machine
have been dry out and the scale had create a small layer which have make some
parts to stuck.
case the propel inside the volumetric dozer part number 5 or 26 at page 4 to
the parts diagram at the link below have been stuck.
is rotating inside the volumetric dozer and with the sense of a magnet attached
to this propel the machine counts the rounds have been made so the volume of
water pass through it. So this propel is stacking or partially stacking thus it
loose the counting of the water passing through it thus it can leave much more
water for every coffee.
solution is first to perform de-scale for a couple of times one perform each
day and try to leave the solution inside the machine for about 30 minutes and then
flash it out with fresh water. If you do the de-scale for three days and the
problem insist then you need to disassemble the machine and manually de-scale
the volumetric dozer. The dozer is composed from the upper part and lower part
and inside is the propel. If you turn the top and bottom part in opposite direction
the dozer will open like a shell and inside you will find the rotating propel.
Clean very well with a brush so the propel rotates freely. Assemble the dozer
back and try the machine without the side panels to be sure that everything works
normal again. If by any chance you still have the problem (this case is only
one in thousands) just replace the dozer with a new one.
one in 100 thousands that the electronic board is bad and cannot receive the
pulses from the dozer and in this case you need to replace the electronic board
but as we mention this is less possible.
SOURCE: After descaling le Cube two flashing buttons won't stop so can't
I had the same issue. This is what a did:
Turn off the machine
Remove the tray/container and leave it outside
Turn on the machine and this time the power button should be flashing (preheating) then hold both cup buttons for 3 sec and it will be back to normal opertion....
For some reason the sensor needs to read that the tray/container is out of the machine...
SOURCE: My brewer will not brew
There isn't much you can do with the machines other than descale them. They are very difficult to take apart and work on, since they are manufactured with locking plastic tabs that have to be broken to get them apart, unless one has special tools, which I haven't been able to find. If you can get it apart, you may see the clogged water hose, and be able to replace it, but it's sure not easy.
If the machine is still under warranty, enforce it.
Wish I had better news, but these machines are not made to be easily serviced.
