Recovery Commander™ can restore your non-booting system back to normal. It only takes a few minutes to get your system back up and running. Recovery Commander provides enhanced tracking and recovery features for unparalleled protection and can usually avoid the need to reload or re-image your system. And unlike Windows System Restore, it doesn't require you to successfully boot Windows to restore your system.
For you to Stop it you need to stop the services
running for it. Follow the steps below.
Click on Start and then Click on run. Type
msconfig. In the System Configuration utility screen click on services tab (Its
on the Top). Once you are on that screen check the option Hide all Microsoft
services. Then look for Recovery Commander. Uncheck that. Uncheck the Hide all
Microsoft applications again. Click on apply. Then click on OK. Reboot the
computer. You will System Configuration utility screen. Check the Option Don't
show this message again and then click on OK.
Note: DO NOT uncheck any Microsoft Services.
If you want to delete it or remove it from the
computer then install Revo Uninstaller (Freeware).
