The N60 uses standard 35mm film (also known as 135). 35mm film usually comes in 12, 24, or 36 exposure rolls, any of which will work. 35mm film is available in black-and-white, color transparency (color slides), and color negative (color prints). It's also available in infrared, both color and black-and-white, but the N60 will not work with infrared film.
35mm film is available online and at any camera shop. Many department stores, drugstores, and even supermarkets also carry film, though not as wide a selection as a decent camera shop.
SOURCE: Nikon N60 SLR camera
It is more likely that the tab has separated from the plate it slides on. The spring is attached to the plate with the tab sticking out from it. I have repaired these in the past by boring a small hole in the backside of the tab and use a screw to re-attach it.
SOURCE: I have a Nikon N90s /film 35mm slr. I haven't
If the switches and contacts are dirty that would do it. If that happens the cost of service may exced the cost of buying a used one.
SOURCE: do the old AF lenses
Hi ericm675, Yes they will. What you run into is were one uses a auto focus lens on a newer digital such as a D40. Some of the new digital cameras do not have the drive gear to turn the autofocus on the lens. Those newer cameras use electronics. Look on your camera lens mount at 7:00 you will see the drive pin. Look on your old autofocus lens you should see a slot where that pin fits. Hope this helps you.
