Sc-195
SOURCE: Why is there no reception after running autoscan?
Ensure your tv is in the mode of broadcast in you area...if local broadcasting is in digital ensure the tv is set to digital. Ensure that the aerial/antenna is fully working and correctly connected. You can check this by attaching another tv to it.
Try another autotune after the above has been carried out.
If it does not work try a reset and another retune, ...using your owner's documentation ensure that the setup is followed as specified.
Disconnect all other peripherals from the tv during this procedure.
If the worst has happened the tuner may need to be corrected. It does not sound as though there is anything makorly wrong.....hopefully
GOOD LUCK
