Question about Cavs JB-99
My machine was in a bar that burned and has lots of smoke damage, is there a way to save it?
We were playing in a bar and over night the bar had an extensive fire and my machine received extensive smoke damage, there is no fire damage to the exterior but I can't get it to play. Is there a way to save my music?
    Master:
  • 487 Answers
If there was lots of smoke it could be the laser lens is dirty, usually you can take off the cover and clean it with a soft damp cloth to fix a dirty lens.
Posted on Oct 11, 2014
SOURCE:
How do i get the drum beat to stop right away as soon as i hit the foot switch
Save up and employ a real drummer. We're quite cheap to run, needing just Newkie Brown and copious kebabs to perform for hours every night.
Jul 19, 2016 | Roland DR-3 - DR. RHYTHM Drum Machine DR3
Load pop when running ,shuts down,smoke from back,burning electrical
You have a tub "Balance" bearing that is Shot! Goner! Dead! And your Tub may be a goner too! Depending on the extent of damage, you said you saw SMOKE! I never seen smoke from a washer unless someone throws a Concrete Block Stone in one on You Tube! ON PURPOSE! You have to weigh the age of machine vs the price of a new/USED one. If your machine is over 7 years old. Get a new One! Not a LG for goodness sake. Get a Whirlpool or a Maytag. I just bought a used one (Whirlpool) for $150. Still works 2 years later right next to the Dead $1600 LG I bought 6 years ago! The man I bought it from is in Rosamond, Ca. right by Edwards AFB. He has a garage full of them and guarentees his machines. There are a lot of people that do this. New is Not always the best!
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
Dec 26, 2013 | LG WM-2032H Front Load Washer
When my engine is ticking over and then i put the accelerate down white smoke comes outand theres a smell is it my turbo thats away
hi.
white smoke would normally mean water is being burn in the cylinder. if it is a sweet, sugary smell then the head gasket is almost certainly blown.
greyish smoke with an burnt oily smell would point towards the turbo oil seals being the problem.
either way, this should be checked properly and quickly by a specialist to find exactly what the problem is. if either of these problems are left to develop, it could result in serious engine damage, and costly repairs. if sorted soon enough, it could save you a lot of money.
hope this helps.
Jun 29, 2011 | 2003 Land Rover Freelander
Hi, last night my smeg dishwasher cut after 20mins. There was a lot of smoke and a strong burning smell. We have taken off the front panels, however there is no sign of any burnt out wires. Do you have any...
Many times if the wiring becomes loose in the connection box itself (where the house
wiring connects to the machine itself). The wire nuts will burn out and create
quite a smell. I have seen this numerous times where aluminum wiring was
connected to dishwashers. (Note, make sure breakers are off to the circuit before
removing the cover to inspect as the leads may be in contact with the metal cover)
If this is not the problem, I would recommend having a licensed electrician over.
Apr 24, 2011 | Dishwashers
No Power at all. Fuse blown-Burn smell from fan area.
You did a lot of damage, and replacing the fuse and trying it has caused much more.
There will be about seven blown parts on the amp and a dozen on the power supply. To give you an idea of the extent, the WHOLESALE parts cost is roughly $50, including the main power supply switchers IGBT's which cost nearly $20 for the pair by themselves.
I have repaired several of these and the larger cousin the PMP5000. It is a lot of skilled work to repair these.
The cause is a marginal insulation between layers of the multi-layer amplifier board. Usually the rearmost amp arcs between the layers. This fries three big switching transistors followed sometimes by a metering resistor and two small surface mounted transistors. A zener diode often goes. The cancer and burned area has to be ground out with a dental drill and new wire replaces the blown circuit traces.
If you are under warranty, take the unit for replacement.
The thing that can arc the amp is if speaker leads are marginal or get pulled out while under power. Excessive volume, especially pulses at high level can break down the insulaton causing the arc and failure. The black smoke is likely from the metering resistor.
Jul 30, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Chainsaw is smoking excessively when in use
White smoke is usually associated with burning antifreeze in an automobile engine, but in this case, trying to cut wet wood might be suspect. The chain must be properly sharpened and the teeth cut toward you on the bottom run of chain. When the chain is properly adjusted, it should not droop from the lower edge of the bar, but no so tight that you can't turn it by hand. Forcing a poor cutting chain into the kerf will overheat the chain and cause it to become loose quickly. Hope this helps!
May 29, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Washer smoking
If it's smoking you have a serious electrical problem in the unit. Unless you're experienced in electrical problems call a repair service for this one. It's not worth burning the house down to save money on this one.
Apr 26, 2010 | Maytag MAH6700AWW Neptune Front-Load...
Smoking on start up
sounds like the valve seats are getting dried out.you can some conditioner, they are rubber seals around the valves keeps from getting oil into the cylinder walls
May 10, 2009 | 1991 Mazda MX-5
ADMIRAL REFRIGERATOR/FREEZER BURNED
admiral is a maytag owned company which is now owned by whirlpool. so contact maytag or whirlpool. google them should be eay enough to find..
Nov 02, 2007 | Admiral 26 cu. ft. Side-By-Side...
Televison & Video Logo
Top Cavs Televison & Video Experts
Ekse
Are you a Cavs Televison and Video Expert? Answer questions, earn points and help others
