Laptop is very light use and she is not the type of child to damage it.
1. Does YOUR charger work on her computer? If yes, you need to replace her charger.
2. If YOUR charger doesn't work on her computer, then the problem is most likely a broken power jack (or a "cold solder joint" on the power jack). The power jack is mounted directly on the motherboard, therefore the entire computer needs to be disassembled to repair it. Here's a link to a YouTube video showing this repair:
https://www.youtube.com/watch?v=OoT9XVn5Y2s
Best of Luck!
SOURCE: Dell latitude D600 battery charge light flashing
You have a ground fault issue in the DC JACK.
There are escentially 4 circuits in the jack and one is not making contact.
1: Negative Charge circuit (outter ring)
2: Negative Run circuit (outter ring)
3 Positive (Inner Ring)
4: Signal (center pin)
I believe the negative charge circuit (outter ring) is not making contact internally. Typically what happens on that model DC Jack is the tension contact metal becomes fatigued, and does not touch the outter ring.
This could come from Heat causing early fatigue of the metal.
Or normal wear, the metal has simply worn out from regular insert/removal.
Don't forget to rate suggestions
That usually indicates battery is beginning to go bad. Eventually it will not hold a charge and will need to be replaced.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
SOURCE: Dell Latitude D430 laptop. Laptop
the issue seems with the inverter board of the machine and chek once the machine at any other place.
SOURCE: Vostro 1500 Charger Light goes off when plugged into Laptop
Which window is running on ur laptop ?
SOURCE: Dell Latitude D600 won't accept charger
Had the same problem, My other Dell charger would work fine but the original one that came with this laptop would throw an error message that the Charger wasnt recognized. None of the suggestions on the forums worked.
I held the chord by the circular flex thing at the end, and pushed in the power pin with force into the laptop, held it for a few seconds and now it works fine. If you push the pin slow and gently into the laptop, it doesnt recognize the adapter. I think the problem is either with the power chord connections inside or with the adapter inside the laptop. Try it!
