When the air conditioner is running and you turn it off, a blast of water comes down on the passenger side inside the car. How do I fix this?
SOURCE: air conditioner 2004 kia optima
CHECK AC COMPRESSOR CLUTCH FUSE AND RELAY.MAKE SURE POWER IS GOING TO COMPRESSOR CONNECTOR.IF NO CHECK FUSE AND RELAY.IF YES.YOUR PROBLEM COULD BE AC CONTROL SWITCH BAD OR BLOWER MOTOR.COMPRESSOR CLUTCH SHORTED OR OPEN.AC PRESSURE SENSOR BAD OR REFRIGERANT IS LOW.
SOURCE: When I stop it leaks what appears to be water out
are you running your ac cause that sounds like the condensation drain tube
SOURCE: My car used to rumble when I turned left or right.
Check the tie rods or maybe when you replaced the cv axle it wasnt splined in properly
SOURCE: water from the condensation of the air conditioner
crawl under car and look for a hose on the passenger side stick something up it carefully,, if not you will have to tear stuff apart to get into the area of the condensor
SOURCE: I have a 2004 kia
check windsheild and fresh air intake area at rear of front hood for leak/ seal prolems. Also door weatherstipping , rust should be a problem yet but that depends on your physical location
