Question about Fisher and Paykel Aquasmart wl80t65c
My washing to load model no aqua smart is stoping every time on 38 minute on all kinds of wash and I have to push start to work but after a fire minute it stop again and say help, my load is out of ba
My washing to load model no aqua smart is stoping every time on 38 minute on all kinds of wash and I have to push start to work but after a fire minute it stop again and say help, my load is out of balance redistribute load and press start.
  • Fisher and P... Expert
  • 555 Answers
These are a common problem for AquaSmart machines.
Your AquaSmart machine requires 4 new suspension damper rods & 4 top bands,
Posted on Dec 14, 2014
SOURCE:
  • 3 Answers
SOURCE: wont wash
Remove lid then control panel. Unhook all terminals, remove control board, then second "box" which is further away towards back of machine. Sensor is 'back/right," under this second box. Unhook connectors & remove wee sensor carefully. On the side of the sensor is a tiny plastic button the size of a pen top. This should move in & out freely. It is spring loaded. If it sticks replace it. Good luck on your mission.
Posted on Jun 08, 2008
  • 639 Answers
SOURCE: model GW609NZ f&p washing machine/smart drive 6.5kg excellence
Dear herman worth and Guest also!,
ngfam1 here for you!
I am happy to be of assistance!
FIX IT NOW BEFORE IT GETS WORSE AND COST MORE!
Here is a good service that I recommend to my customers,
in our 65 year old appliance business!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS. Pleas egive me a good rating here in fixya.com before you sign out!
Posted on Aug 26, 2008
SOURCE: Aqua Smart washer says, "clean cycle" need after 125 washes. How do I do that?
It's under the "lifestyle" section of the wash selection menu. It was called "Clean me" on my machine
Posted on Jun 20, 2009
  • 713 Answers
SOURCE: Fisher and Paykel Washing Machine
Hi just found your posting.Do you still require help?The problem with your machine sounds like your suspension rods are faulty.Please reply and I can help you rectify this fault.Looking forward to your reply.
Posted on Jul 16, 2010
richroth
  • 9472 Answers
SOURCE: start wash cycle, within 2/3 minutes machine stops
From left to right, which number lights are on. 1 on 2 off 3 off 4 on etc.... There should be 8 lights.
Posted on Feb 10, 2011
When i push the start button nothing comes on,if i unplug the machine and plu it back in the machine works fine for a while than stopes working
You need to offer more info for us to assist with possible fault.
When you say unplugging/re-plugging it allows it to work for a while, please explain - do you mean it works for a few minutes, it for a few hours or for a few washing cycles/days? Does it stop part way through a wash, or once started will it always finish a wash before failing again?
Dec 15, 2013 | LG Wm2688hnma Front Load Washer wm2688hnma
Fisher paykel aqua smart fault 49
Fault code 49 is water valves, But the Aqua-Smart board is outputting the wrong code here, The Smart pump has blown the water valves fuse, A common thing in Aqua-Smart Machines.
The Smart pump has jammed with lint and caused over current to the board and taken out parts on the board that drive the pump.
Best to get a new/recondition board for your machine.
Apr 20, 2013 | Fisher and Paykel Aquasmart wl80t65c
Washing machine top loader aqua smart the lid cannot lock while washing. I have tried switching the machine on and off, still won't work. This happened a little while ago but then is rectified i
Is the lid lock tang on the lid ok & not broken.
You need to jam the lid lock lever in the lid lock down for it to do a wash.
This is where your lid lock is
Feb 21, 2013 | Fisher and Paykel GWL11 Top Load Washer
My Fisher Paykel top load aqua smart washer won't
it wont spin if there is water remaining in it,check pump for restrictions or anything jamming it if good replace pump
Apr 27, 2012 | Fisher and Paykel Washing Machines
Fisher@paykel aqua smart washer shows fault code49.
Fault 49 on F&P agitator models is bad cold water valve or wires on it disconnected.
Apr 25, 2012 | Fisher and Paykel Washing Machines
Washing machine was operating machine stoped 10 minutes after operating and will not start water is in the machine it did not drain
Hello, first check if the breaker triped in the electrical panel box (fuse box--old name). If it has not triped a breaker. Unplug your washing machine and wait about 10 or 15 second and replug the washing machine into the electrical socket. Don't turn it on. There should be a reset button. Push the button first, then turn on your washing machine. I hope this works for you. GB...stewbison.
Aug 25, 2011 | LG WM-2277HW Front Load Washer
The digital timer skips 9 minutes out of the wash cycle. After starting the normal 140 degree wash cycle (46 minutes) the washer will start and wash normally until it has counted down to 41, then it...
hi shotgun - sometimes the mieles with auto adjustment functions do make changes to the wash time - usually based on a smart sensor technology.
Unfortunately I have no data or information for your particular model, I have info on earlier & the latest models only. In hindsight what this function does is adjust water levels based on the load weight or amount of the wash, the computer then calibrates the water levels and accordingly the amount of time to wash.
Eg - 4 kg load would be longer than say a load 1.5kg to process - if can understand this concept. However I cannot be 100% certain it applies to your particular model, if the user manual is availbel it may just pay to read thru in case it applies to the washer.
Jun 21, 2011 | Miele Super Novotronic W1986 Front Load...
F&P machine is a top loador, not sure what model,( it has no agitator )and is approx 5yrs old. cold water has been used. it now needs to have a hot wash, what do you recommend to clean the machine...
Hi just read your posting.Depending what country you are in it is either an AQUA SMART OR AN ECO SMART.Try a cycle with the efficiency button turned off and selecting a warm wash on normal or heavy duty or regular.This will make the machine wash the clothes with more water.Please reply on how you got on or for further help.Looking forward to your reply.
Sep 21, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel Wasehr won't power up
brand new???? call an authorized servicer. as long as your electric is good .all you can do
Jan 27, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel Aquasmart wl80t65c Logo
184 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
