try this site for a manual?
http://www.productmanuals.org/lp/?category=Whirlpool&utm_source=adcenter&utm_medium=cpc&utm_term=whirlpool%20manual&utm_network={}&utm_campaign=FM+IAC+Brands+02-08
For the most part, Frigidaire washers don's have fuses. I don't recall any that I've worked on. If the washer doesn't power up, always start with the wall socket. Take a lamp or something else that works and plug it in. This is a quick test for power. If the outlet is good (lamp lights up), then it can get complicated. Some of the washers have a user interface that goes bad and it could also be a board. One finally note, some washers will have a power filter, I've only run across one that's been bad. Good Luck!
You may have power, however if a circuit board fails, all the power in the world won't start the washer. You need a technician to test the circuit for internal damage.
check for powers and grounds at the pump electrical connector with someone activating the pump.of you don`t have any then check the fuses with a test light.if you do have power and ground at the pump and it has a good connection(no corrosion or dirt)then you may just have a bad pump this happens sometimes.
Double check the cord to make sure all the wires are hooked up to the washer correctly, check your breaker/fuse box to make sure you don't have a tripped breaker or blown fuse, and check the outlet for power by plugging a known working item into it or using a circuit checker.
If the washer is getting power, try holding the power button down(if there is one) for 3-5 seconds.
If that doesn't help, here's a link to LG's customer support options: http://www.lg.com/us/support/contact-customer-service
Make sure there's power getting to the washer. Check for a
tripped circuit breaker or a blown fuse. Check the wall socket for
power. Sometimes the power cord disconnects at the washer, if this is
the case, the wiring must be repaired or replaced.
Mine does this if there is the tiniest power interruption. Even if the lights only barely flash and nothing else happens in the whole house, the washer lights up. I just cancel mine out. It is not going to start running, and I don;t think there is a solution to this annoying little glitch.
