Kodak Easyshare C813 Digital Camera Logo
A
Anonymous Posted on Oct 10, 2014
Wear can I get My camera repaired?
Will not turn .I tried new battereys.
Herby0802
Level 2:
  • Expert 48 Answers
  • Posted on Nov 26, 2014
Herby0802
Expert
Level 2:
Answers
48
Questions
0
Helped
12160
Points
182
7helpful
2answers
My motorola cliq just turned off and will not turn on i tried charging batterey but nothing happens the screen staays blacked out and the key board only lights up when plugged in to charger
my motorola cliq just turned off and will not turn on i tried charging batterey but nothing happens the screen staays blacked out and the key board only lights up when plugged in to charger
tip
If your JVC Cm Pause Condensation
JVC camcorder sometimes have a bug, it's call condensation, it;s make your camera not work and never accept any cassete, the solution is very easy just turn off it, and change your camera batterey with another one , not same batterey . ...it working !
on May 24, 2010 • Cameras
When I zoom in the camera shuts off
u need to charge it or put new battereys sorry cant spell or u should get a new camera because if u put battereys in or charge it it will not work
sorry i am trying to be helpful i fix cameras but i have to see it first sorry
YOUR WELCOME IF THIS WORKED
Camera turns off within seconds batteries are new
Are You Using Regular Or Alkiline?
cameras eat batteries fast. the best cameras have rechargable battery packs.
i'd use energizer or duracell. try to stay away from alkiline rechargables as they wear out fast. try Nickle Medal Hydrate Batteries (NiMH).
1helpful
Losing date and time when removing batterey on Kadak Z812IS
Take the camera to a repair shop and tell the tech man to replace the "super capacitor."
Problem will be fixed
Problem
replace the battery as it is old so the power is used.or if it is new check whether if it is of any local company batterey.or any reputed battery such as duracell.
thanks.
Won't start...no clicking, buzzing...nothing
hello it sounds like batterey terminals need to be cleaned disconnect off batterey clean batterey terminals with a post cleaner cable terminals wire brush reinstall try to start check batterey for 12volts if not jump take it for a good ride or charge batterey goodluck
Latch on batterey door is borken,
here is Vivitar's USA number: (800) 592-9541. They should have what you need
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
