Will not pair
You need THREE-WAY SWITCHES to be able to use them in tandem. SPDT (Single Pole Double Throw) switches.
You cannot install two ONE-WAY switches (SPST - Single Pole Single Throw) to switch from two loacations.
You CAN, however, use ONE Three-way dimmer on one end of the room, and one Three-way 'regular' switch on the other, if dimming from just one place is adequate for you
For dual-channel memory configuration (2), you may:
• install identical DIMMs in all four sockets OR
• install an identical DIMM pair in DIMM_A1 and DIMM_B1 (yellow
sockets) and another identical DIMM pair in DIMM_A2 and
DIMM_B2 (black sockets)
* Always use identical DDR2 DIMM pairs for dual-channel model. For
optimum compatibility, we recommend that you obtain memory modules
from the same vendor.
