When outside temp goes below 50 door opener will open with remote but will no close with remote
Colder weather solidifies the grease to add extra friction on the moving door in the track. Increase the downward close pressure. Its a screw on the motor box. There are 2 sets of screws one for open and close pressure the other set for close and open distance
There are many reasons that I can speculate on for this happening but they would all be my best guess! The First would be is that their is an issue with the logic board /replacing this part can run from $45 up to $80 .The board has a antenna that runs to the outside of the machine that receives the signal from your remote...The transmitter. This board is a direct link to making your machine operate..Now lets take a look at some cheaper alternative fixes that we can try before hand to do a process of elimination...Make shure the batteries in your remote are fresh and strong...if that's ok then the next thing I would say is your remote old? I have found that in keypads and remotes that the contacts do wear out when they become old from pressing the buttons thousand of times over the years so to keep that in mind you can try replacing the remote...The cost of the remotes run between $29 and $40 on average ,but before we think about that lets keep thinking about process of elimination! Next the antenna that comes from the logic board sometimes does not receive a strong enough signal from your remote because you may have a garage that is brickfaced and has no windows on the garage door...this causes your transmitter (remote ) to send a weak signal to your opener and you would have to be fairly close to the opener to make it operate that's because the signal becomes weaker penetrating the steel or wooden door you may have ...windows allow the signal to be stronger. So here is another thing you can try to help boost the signal to the machine...The antenna that hangs from your garage door opener is made from an aluminum wire that is coated and is usually about 10" inches long , I have found success by extending the wire another foot with the same type aluminum wire ...you can just splice them together and let them hang from the machine! These are the things I would try to do first before spending money on remotes or boards but if your machine is a older model like 20 years old a lot of the parts become obsolete so by saying that it may be time to invest in a new opener! There are many different scenarios that I can dream up but without knowing the model and year of your opener..if you have a universal remote or the original / if you have windows on your garage door or not I would just be guessing at why you are having this problem! You can also call Liftmaster technical support and give them the model# and year of manufacture info which you can find behind the light cover on your machine and they may be able to help you ...if you have a newer machine within a year old ,you may be covered under a warranty! I hope I was able to give you a little insight into some of the things that may be causing your problem , Good luck Sincerely Glenn
SOURCE: Door suddenly will not close without holding the
It definitely sounds like a sensor problem. In normal operation, one sensor will have an amber or yellow light on, indicating power to the sensing circuit. The opposite sensor should have a green light on. If the yellow light is not on there is no power to the circuit due to a broken wire or circuit board failure. If the green light is not on or is flickering, the sensors are not aimed at each other or the light path is blocked.
SOURCE: garage door will not close when using the remote
Check to see if your child/animal security beam is working correctly. It is an "Electric Eye" mounted about 12 in off of the floor on two mounting points and one side shoots an infra red beam across to a receiver. These points must be reasonably aligned to flash a beam (cannot see) from one point to another. This beam keeps the door open if it is interrupted . If it is not aligned, then the door opener sees a problem and will not close the door electrically. You must aligned the beam by bending the transmitter or receiver untill you can close the door by the remote. Also check to see if something placed in the garage is not blocking the beam first.
SOURCE: have a 2006 Liftmaster professional 1/2 h.p garage
The opener should have an antenna wire hanging out of it. Did someone/something hang on it?
SOURCE: The garage door opens on it's own. The
i think there is some sensors not working there. as par a i undestant the logic is there two sersor guide for opening and clossing to terminate commands programs. its either slide swhicth type or led photo diode sersor.
SOURCE: the garage Remote control was working normally at
It could be the garage door motor that is acting up. Try closing it with the button in the garage. If that's not the case, you may need a different garage door opener.
